meth kit mount
meth kit mount
for those who have done a trunk mount meth kit, where did u run the tubbing? and is it ok to use the black flexible tubing instead of the ridged crap u get with? if someone has pics that would help
I ran the tubing through the upper front of the spare tire well. From their to over the evap canister, then to the frame rail and followed the fuel/brake lines to the front engine cradle. Then from from frame rail across inside of the engine cradle to the lower cold side charge pipe where I'm tapped in.
check my cardomain in my sig. Go to page 4. I have install pics of my meth kit. Basically mounted the bottle on the right side. Drilled a hole. Ran the line given through a bigger line for protect. Followed underside of the car up to the cold side charge pipe
ya im gonna be in contact with u when i have questions, i like the way u did it, so ill do it that way, guess ill start with the mounting bracket u made. gotta have that. thanks.
do you have to put it in the Spare tire spot tho? Or the windshield washer tank?? those the only options??
If/when I gets a kit, cant I jus Mount it in my trunk off to the side or somethin an run the wires down??
Just make sure if the tank is mounted higher than the spray nozzle to have a check valve. But it a good idea to have one any who.
is that a flow meter t'd into the line i see? And if so what make and how much $$$$?
Methanol Injection Check Valve Devilsown
here is an example, other companies make them too you'll have to compare pro's con's yourself. But i have a complete kit from Devils own and it top notch and great customer service!
I was jus wonderin tho... cuz I've been in a couple spots with my old car where I had to throw my spare on at a horrible time, or times where I wish I would've bought a spare
not to thread jack but idk how to post pics i have a link to my pictures https://www.cobaltss.net/forums/pict...ctures-197655/
