Meth users! A question!
Old Sep 9, 2013 | 12:39 PM
cw383's Avatar
Hey guys. I have a metallic lower Hahn charge pipe. I'm getting ready to get it powder coated. Are you guys using a bung or is screwing right into the metal Acceptable?
Old Sep 9, 2013 | 12:48 PM
blueLNFftw's Avatar
IMO, if you havent had it powdercoated yet I would weld a bung in for it over just tapping the metal. Just my opinion though.
Old Sep 9, 2013 | 03:25 PM
BLOWN GOAT's Avatar
I was a little worried when I seen the title lol but I welded in a bung before having mine re-coated just seems properly done that way
Old Sep 9, 2013 | 03:44 PM
alerosaint's Avatar
I kicked the habit...sorry for the useless post but I couldn't help....but i did drop my love for meth....well methanol
Old Sep 10, 2013 | 08:39 AM
r3v07ut10n's Avatar
I use the TB spacer that BYT made, i didnt like the idea of tapping the pipe.
Old Sep 10, 2013 | 10:55 AM
blueLNFftw's Avatar
I have a spacer, however, OP is talking about a welded in bung.
Welding in a bung > Spacer > drill and tap
Old Sep 10, 2013 | 01:50 PM
tomj77's Avatar
Bung
Old Sep 12, 2013 | 12:51 PM
sc4door's Avatar
Anyone know anybody who makes spacers with meth ports? Or can anyone tell me where you're getting the bungs from?
Old Sep 12, 2013 | 12:54 PM
blueLNFftw's Avatar
1/8NPT
eBay it for pennies.
Old Sep 12, 2013 | 01:00 PM
sc4door's Avatar
Awesome. Thanks
Old Oct 8, 2013 | 04:52 PM
hungryhip-ccp's Avatar
Spacer will give you much better results. If you tap the boost tube do it as close to the tb as possible.
Old Oct 8, 2013 | 05:30 PM
Extreme Dimensions's Avatar
^THIS.
creepy title is creepy.
Correct though, weld on bung FTW.
Old Oct 8, 2013 | 07:47 PM
ive been injecting for 8 months thinking about switching to the main vein (intake mani lol)
Old Oct 9, 2013 | 05:45 AM
hucks1987's Avatar
I agree with Riceburner..... Adding it right to the intake manifold, and maybe a dual sprayer... here is why
I know the older hahn piping was made of steel, steel rust.. Meth/water makes it rust faster, Also, the powercoating on the inside will start peeling... ASK ME HOW I KNOW.....
Depending on how you have it set to spray, some of it will end up hitting the TB plate and when you let off, it will drip down into the intercooler
The intake mainfold is thick enought to drill and tap... Ill be doing that in a few weeks once i get all the parts for the dual sprayer.....
Old Oct 9, 2013 | 07:19 AM
ATLsilverSS's Avatar
Thing i hate about drilling thd intake mani is its impossible to get all the shavings out
Old Oct 9, 2013 | 07:37 AM
Rick Bragstad's Avatar
Mainline that ****. Smoking it rots your teeth, not to mention sucking glass dick is gayer than sucking flesh dick.
Old Oct 9, 2013 | 07:52 AM
blueLNFftw's Avatar
Take it off the car...
Old Oct 9, 2013 | 09:25 AM
hucks1987's Avatar
um, clean it with dawn dish soap... get all the oil out, then it wont have anything to stick to!!!
Old Oct 9, 2013 | 10:33 AM
oh p.s. i opinion was for a supercharged car, i didn't realize this was for t/c.
it is best to have it AFTER the t/b... actually i don't think you could do it before the tb lol
Old Oct 9, 2013 | 10:35 AM
blueLNFftw's Avatar
I mean you can.....
Old Oct 9, 2013 | 10:44 AM
sydewayz's Avatar
Anyone dyno after being tuned for meth and see the difference in power? Was it worth it?
Old Oct 9, 2013 | 11:29 AM
I say you just hotpipe and a ton of meth
Old Oct 9, 2013 | 01:25 PM
Take it off the car he says. No **** sherlock
I cleaned it with soap and water, seafoam, it still had shavings in it. I tried to get them out the best i could. No issues so far so no damage was done. Just dont like it. Im gonna have to tap it again twice too. One to add a larger fitting for my -4 vacuum line and one for meth
Old Oct 9, 2013 | 04:03 PM
BLOWN GOAT's Avatar
I cleaned it with soap and water, seafoam, it still had shavings in it. I tried to get them out the best i could do issues so far so no damage was done. Just dont like it. Im gonna have to tap it again twice too. One to add a larger fitting for my -4 vacuum line and one for meth
Try cleaning it better before you start? Its not that hard just take your time and do it right I wouldn't leave any shavings behind and risk it. I remember last year I pulled mine for the first had it spotless in under 45min brake clean or carb cleaner go a long ways
Old Oct 9, 2013 | 09:58 PM
tomj77's Avatar
also spray the inside of the pipe with galvinizer, keeps it from rusting
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
Oct 13, 2015 09:32 PM
Sep 27, 2015 08:53 PM
