Methanol Kit...
Old Jan 17, 2015 | 07:03 AM
:ninja:'s Avatar
Methanol Kit...
Anyone here running a meth kit w/ direct port injection? If so what kit are you running? Also would having a nozzle post ic on cold side pipe be bad before maf on a maf relocate?
Old Jan 17, 2015 | 07:54 AM
blueLNFftw's Avatar
You can't spray meth into the maf. It will fail the maf and reek havoc lol.
Meth goes after maf
Old Jan 17, 2015 | 10:38 AM
:ninja:'s Avatar
True.. Has anyone did a DPI setup??
Old Jan 17, 2015 | 02:54 PM
cw383's Avatar
I think he may be referring to having the injector or injectors tapped directly into the intake manifold. I feel 4-5 inches from throttle body in the lower charge pipe allows best cooling and more time to atomize before entering valves. I used a 10GPH injector and with 09CobaltSS1's help knocked 4/10ths off my 60 to 100 time. The stuff does work.
Old Jan 17, 2015 | 03:39 PM
:ninja:'s Avatar
Yes tapping into each runner in the intake manifold with a nozzle. Throttle body spacer wouldn't really allow even amount of meth into each cylinder..
Guess having a nozzle after maf on cold pipe would work. Thnx
Old Jan 17, 2015 | 04:38 PM
tomj77's Avatar
that would work. wouldn't be to hard. but what for? why not just spray it the normal way
RoelSS
Nitrous Oxide
Nov 7, 2010 01:18 AM
2K5SS/SC?
Aug 19, 2007 11:38 PM
rickyw
Apr 7, 2007 12:53 AM
2K5SS/SC?
Apr 5, 2007 06:50 PM
