Misfire?
Old Nov 17, 2010 | 08:47 PM
gotboost?17's Avatar
Nothin Stock
Misfire?
...so i changed my plugs to the NGK 3787( as pantherqs requested)about 2 1/2 weeks also then went logging a couple days after that and did a scan and showed a misfire(no engine light and who knows now long ago it was thrown)so i cleared it..so today i started it let it warm up for about 3 mins then started driving and then started backfiring wit some misfire and threw a engine light.....so i went to the dealer and they scaned it and came back wit a cylinder misfire on #4....i said okay fine ill be back to make a appointment bla bla bla...any ideas, tempatures were about 48 degress,not warm enough? i still have full warranty but i hate the dealers touching my car lol
Thanks guys
Old Nov 17, 2010 | 09:02 PM
Grishbok's Avatar
Not sure what your asking, you can either a. put your stock plugs back in and see if misfire goes away, or b. swap cyl 4 plug with cyl 3 plug and see if your misfire suddenly appears on cyl 3. If so, bad plug.
Old Nov 17, 2010 | 09:07 PM
ssblackstealth's Avatar
corn gas ftw....
i had those in my tc for a week and i got misfires like crazy!!! i had em gapped perfectly and everything...when i went to take em out they were more black then the stockl ones with 40k miles on em lol, i asked vince why this was and he said some tc's like em and others not so much...so just got new plugs of the stock version
Old Nov 17, 2010 | 11:12 PM
tomj77's Avatar
get stock plugs. nothing else seems to work
Old Nov 18, 2010 | 05:58 AM
Nothin Stock
yeah thanks guys...what should i gap the stockers too?...i gapped the NGK's to .031 if i remeber correctly
thanks guys for the reply too
Last edited by gotboost?17; Nov 18, 2010 at 05:58 AM. Reason: Automerged Doublepost
Old Nov 18, 2010 | 10:39 AM
corn gas ftw....
.032-.034
no prob man
Old Nov 18, 2010 | 05:35 PM
ronn's Avatar
Get them here..I just did. Best price for sure:
Click *YES* on the pop up
https://www.rockauto.com/catalog/x,c...8X%2529%2BDOHC
More Information for ACDELCO 41108
Old Nov 18, 2010 | 08:41 PM
Nothin Stock
k thanks guys
also will misfire f*** my car up?
Old Nov 18, 2010 | 09:29 PM
drewbroo's Avatar
under an extreme condition, you could melt a piston
Old Nov 18, 2010 | 10:37 PM
tomj77's Avatar
stock ones come gapped at .031ish, u dont have to gap them
Old Nov 18, 2010 | 10:39 PM
tomj77's Avatar
non of those are stock, acdelco is stock
Old Nov 19, 2010 | 05:47 AM
Iam Broke's Avatar
AC Delco 41-108 is made by NGK, it has the NGK part number (ILTR5D) stamped into it above the threads on the AC's. NGK 5476 is the same plug as stock.
Anyway that page also lists the AC's on it 3rd from the bottom.
Old Nov 19, 2010 | 06:07 AM
Nothin Stock
the stock ones i pulled out of the car were .028-.041---->...idoits
Old Nov 19, 2010 | 09:49 AM
Stamina's Avatar
Bought 3787s a while back. Still wondering if I should install them or not. They were a bit pricey, but I liked the fact they were a step colder while already having our recommended gap (helps keep the electrodes properly aligned if a large gap adjustment isn't needed).
I'm torn between keeping/going with stocker plugs (5476s it sounds like) versus popping these in.
Old Nov 19, 2010 | 10:23 AM
Iam Broke's Avatar
I ran the 3787's with 24 psi for a long time no issues.
Since switching to 60% ethanol I put the stock heat range plugs back in.
Old Nov 19, 2010 | 11:27 AM
Stamina's Avatar
Ok, thanks. I may try them then.
Are there any downsides to a colder plug I may not be thinking of?... Perhaps it fouls easier and that's about it?
A friend running colder plugs busted one of his pistons pretty good on a notched NLS. Any reason you can think of that it could have happened due to the difference in plugs? It took out a land. I just can't imagine tapping the limiter would cause something like that, but I can't think of anything else that it could be besides the plugs.
Old Nov 19, 2010 | 04:01 PM
ronn's Avatar
Did you see this among the various plugs listed?
ACDELCO Part # 41108 More Info {#12590701, 12617309, 12620540, 41102} IRIDIUM
SPARK PLUG .035 GAP
The AC Delcos are listed under the OLD PN as well. Trust me they are AC DELCO 41-108. I ordered them!
Old Nov 19, 2010 | 09:39 PM
Nothin Stock
what do they mean when one step colder?....im goin to pull the plugs tommorw havent had time
Old Nov 20, 2010 | 01:27 AM
tomj77's Avatar
when they fire the heat dissipates faster.
Old Nov 20, 2010 | 09:07 AM
Iam Broke's Avatar
The rings gouging into the cyl wall due to excessive expansion from too much heat causes the ring lands to pop. The ring end gaps only allow so much expansion. Once the ends meet and they expand more the ring diameter increases more than the cyl clearance and they gouge into the cyl wall.
Too hot a plug contributes, so does knock and detonation, so does too lean or rich a mixture. Too rich in our engines causes knock too. Too much boost pressure generates more heat also.
Bill from GM has posted many times that it's due to excessive heat.
Old Nov 28, 2010 | 06:42 PM
Nothin Stock
misfire all solved...stock plugs are in
Old Nov 28, 2010 | 11:21 PM
efactor's Avatar
one of them days I'll just replace the stock pistons with Wiseco Forged Pistons so i don't have to worry about heat like the stock one's.
Old Nov 29, 2010 | 08:53 AM
blackrocky's Avatar
That's only if the motor runs extremely lean.
Old Dec 4, 2010 | 06:21 AM
Nothin Stock
okay so its been about a couple weeks now i have the same misfire CEL 1 an 4 wit my stock plugs....im about to bring it to the dealer and say fix this now
Sean Cummings
Mar 9, 2018 12:26 AM
717ssbalt
Oct 2, 2015 04:01 PM
SStevie
Sep 21, 2015 11:37 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Fearedbynone
Sep 4, 2015 10:24 AM
