Misfire Cylinder 1
Old Nov 3, 2012 | 07:31 PM
10Cobalt_SS's Avatar
Misfire Cylinder 1
I keep missing at cylinder 1 on cold start only its not a plug and not a coil i seafoamed my car it went away for about a month... now its back GM tech put top engine cleaner in it and still nothing changed the coil and plug still nothing....
Old Nov 3, 2012 | 07:36 PM
QuickSilver_SS's Avatar
Possibly the dreaded valve gunk on cyl 1 ? Just my first thought sense you said it went away for a month after you seafomed it last time.
Old Nov 3, 2012 | 07:46 PM
was thinking the same i used my boresope, cylinder leak down, and compression tester (Im a Kia Tech) to look and its grimmy and everything check out ok but i shouldnt have to do this every month especially on e85. plenty carbon build up too on the valves
Old Nov 3, 2012 | 07:52 PM
nobody2u's Avatar
I had an annoying cold start misfire in Cyl 3 for the longest time. Dealer tried the plug and ignition coil to no avail. Eventually they replaced the injector and the CEL hasn't come back since. Was done under powertrain warranty btw.
Old Nov 4, 2012 | 03:25 PM
Team SS's Avatar
TTR Powered
have you checked the Cyl 1 injector seal?
Old Nov 4, 2012 | 10:12 PM
only thing i havent check was injector ill probably do it this week
Old Nov 5, 2012 | 12:47 PM
Team SS's Avatar
TTR Powered
Keep us posted
Old Nov 5, 2012 | 12:59 PM
prevsrt4owner's Avatar
Yeah, you guys beat me to it. I'd say fuel-related issue (i.e., injector/injector seal).
Old Nov 5, 2012 | 01:44 PM
vahdyx's Avatar
When I had this issue, I took it in and the techs couldn't figure it out either, so they added new plugs and put dielectric grease and my problem when away.
**Edit** they too didn't think it was my plugs or coils, but they put new plugs in anyway and added the grease. If it's a situation like mine maybe it'll help.
Old Nov 5, 2012 | 08:27 PM
Team SS's Avatar
TTR Powered
Yeah, i had a problem like this before and found out it was an Injector Seal..
Old Dec 20, 2012 | 02:03 AM
finally had it fixed!!! bad injector seal, close call too warranty ends at the begining of the year
Sean Cummings
Mar 9, 2018 12:26 AM
717ssbalt
Oct 2, 2015 04:01 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
