motor mounts
Old Jul 28, 2010 | 06:13 PM
tomj77's Avatar
motor mounts
how easy is it to install the ottp motor mounts? top and bottem
Old Jul 28, 2010 | 06:24 PM
RYRO14's Avatar
You mean trans mounts? They are pretty easy just make sure you do the back on first.
Old Jul 28, 2010 | 06:46 PM
tomj77's Avatar
ya i guess, why does everyone say motor mounts if its the trans mounts they sell and people are installing?
Old Jul 28, 2010 | 07:05 PM
09CobaltSS1's Avatar
The front mount is seriously rediculously easy even with basic hand tools. The rear is a little more involved, but still very straight forward
Old Jul 28, 2010 | 07:26 PM
tomj77's Avatar
would u recomend just the front or both?
Old Jul 28, 2010 | 08:16 PM
They come as a set so you get both anyways. If you are asking if you should do a solid upper motor mount along with the trans mounts then personally, I would say do just the trans mounts.
I have the TTR STOP mounts. After I installed them I had noticeably more vibes down low in the rpms, but it really wasn't all that bad, and the motor torque twists WAY less obviously. A friend of mine has both the trans mounts and the upper mount in his SS/SC. Holly christ dude is it stiff!! It sounds like the car is going to rattle apart when he takes off from a stop.
So I guess what I'm saying is it really depends on what you are looking to do. If you want a really aggressive motor mount setup, then by all means get both. If you want something mildly aggressive, but works really well for the average tuned/fully bolted SS, then do just the trans mounts.
Again, this is just my oppinion....
Old Jul 28, 2010 | 08:21 PM
hiltu's Avatar
i have just the front mount and it did absolutely nothing. Im hoping eventually to get the rear mount and see results, but you should try to get the rear only first and report if it does anything.
i guess i was referring to ZZP mounts, you can buy them individually
Old Jul 28, 2010 | 09:47 PM
tomj77's Avatar
so that would be the stage 2 at ottp where u get both? for like 295 or so bucks?
Old Jul 28, 2010 | 10:05 PM
Yes the ottp stage 1 and 2 will give you both the front and rear trans mounts. The stage 2 is obviously a bit more aggressive, and the better choice IMO
Old Jul 28, 2010 | 10:08 PM
Chevycobaltss3's Avatar
Bro easy as hell you will notice alot more powr getting to the ground by less will hop hopefully in my case I just spin. Bit you'll see alot of vibrations
Old Jul 28, 2010 | 10:14 PM
SunburstSS's Avatar
Even with the stage 1 mounts or do u have the stage 2 ones ?
Old Jul 28, 2010 | 10:54 PM
tomj77's Avatar
they say on there over 300hp u should go for stage 2. what do u guys have?
Old Jul 29, 2010 | 12:22 AM
RYRO14's Avatar
Go stage 2 if you don't you will be mad you didn't. Trust me I kno people who only go stage 1 and regret it.
Old Jul 29, 2010 | 06:09 AM
I have zzp solid mounts, the stage two from ottp ive installed inanother ss and they hold up great, they just vibrate alot like any mounts will.
Old Jul 29, 2010 | 09:25 AM
glhs379's Avatar
Stage 2 here. Only vibe at idle with a/c on
Old Jul 29, 2010 | 09:29 AM
yeah the vibes are pretty annoying with the a/c on at idle, but it's damn worth it
Old Jul 29, 2010 | 09:31 AM
RYRO14's Avatar
Vibs aren't even bad with the ac on totally worth it.
Old Jul 29, 2010 | 09:34 AM
not bad compared to what? an earthquake?
Old Jul 29, 2010 | 09:37 AM
coopercharge's Avatar
I did the TTR Stop mounts and they took about an hour to install. Very easy with basic hand tools. That and I have tried to make the wheels hop and have yet to be able to do so.
Old Jul 29, 2010 | 12:24 PM
TurboTechRacing's Avatar
Thanks for the feed back on the quick install time and also the performance.
Old Jul 29, 2010 | 12:29 PM
Not a problem. Performance is great the vibrations stopped after about 500 miles of driving on first start up they felt like the car was going to shake apart. This is common with all solid type motor mounts though. I replaced the mounts in my 350z with solids and it did the same thing.
Old Jul 29, 2010 | 02:46 PM
tomj77's Avatar
lmao that reminds me of a top gear episode. reviews said this one car was more pleasent to drive, and jeremy said, more pleasent then what? getting stabbed in the face? LOL
ThoR294
Oct 4, 2015 08:44 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Stuff
Oct 1, 2015 05:47 PM
n20saturn
Sep 30, 2015 12:26 AM
