Mpx Catch Can
Mpx Catch Can
Well I was going to buy a catch can and was just doing some research and a few posts says to install it on the valve cover line to turbo but mpx says install it on the pcv line from the valve cover to the intake? Wondering which one is best.
Thanks
Thanks
The line from intake to valve cover is the fresh air inlet. There is no possible way for oil to accumulate in that line. The line from VC to turbo is the vent during boost and up until powell's latest iteration is the line that his separator uses.
What line does his new one use?
so which one causes all the oil to get in the intake?
The one connected from the valve cover to the turbo does. The one on the intake has a check valve on it so air can only be sucked into the engine, it doesn't push air out. Not to many people realize that the pcv fitting in the intake manifold also causes oil to get into the intake over time. Idk if u can do anything about that though. But ya with Powell system the oil from the vent port definitely gets routed back into the oil pan, my pipes are always spotless after that mod
firehawk618
Feb 11, 2016 06:16 AM
SS_2009_TC
47
Dec 14, 2015 03:00 PM
Chris06CobaltSS
Dec 7, 2015 12:36 AM
