multiple cel due to misfire
Old Jan 11, 2011 | 08:12 PM
Boogie_69's Avatar
So i had a cylinder 1 misfire due to a nls while tune engaged. Cleared that out, drove a lil then light came back on. Same deal, same cylinder. I switched coils around and checked the gaps on each plug. Plugs were fine as they were only two weeks old. Drove back to work, car sat for a few hours. Went to lunch break just riding around and light came back on again. Same problem, cylinder 1 misfire, all coils and plugs are fine. Does anyone have any input as to what the problem may be. The only thing that has changed since car was running fine was i installed a k&n sri, But have not yet had a retune. which will be done this upcoming week.
Old Jan 11, 2011 | 08:26 PM
tomj77's Avatar
u check ur O2 sensor? that causes missfire as well.
Old Jan 11, 2011 | 09:18 PM
Iam Broke's Avatar
Comp check & leakdown test is in order. I had lower comp on #3 & blowby at the fuel injector seal, took it apart and found NO teflon seal on #3 injector. Tight mechanical fit on the injector held for 50k miles before the misfires started, got so bad I couldn't get into any boost before popcorn started popping. It started in a pull with misfires at around 5k & lotsa boost.
#3 always was ~10 lbs lower on compression but I just figured the rings weren't seated well...wrong.
Seal was never there, there isn't anyplace it can go & #3 injector came out with the rail on mine, the other 3 stayed in the head with a tight fit.
I see 165-168 psi on all 4 cyls now.
Hopefully you didn't pop the ring lands.
Did you swap a plug or just the coilpacks? Move the plug if you haven't yet.
Old Jan 11, 2011 | 10:03 PM
Boogie_69's Avatar
i visually checked the plugs but have been reading and seen that the autolite xp5263 arent good. Im a get a set of stockers tommorow and put in there then go from there. Also get retuned since i havent since the k&n sri install.
Old Jan 11, 2011 | 10:06 PM
tomj77's Avatar
u know whats weird, my car completly stopped misfiring, i used to get it on idle every other start, so dashdaq said anyway, but haven had any in months
Old Jan 11, 2011 | 10:08 PM
Boogie_69's Avatar
ive read in some places the trifecta tune will misfire when nls. But i was just everyday driving
Old Jan 11, 2011 | 10:26 PM
ssblackstealth's Avatar
corn gas ftw....
mine only misfires if i dont let the temps rise to 180 before i no lift shift, and it does it like a bad habit if its not warm lol ..........pop-corn like said above
Old Jan 12, 2011 | 08:45 PM
tomj77's Avatar
oh, u got autolite, lol that might be ur problem, stockers are the best i think, i had ngk one step colder, they missfired and knocked and gurggled like crazy, went back to stock, my car gave me a huge hug.
Old Jan 13, 2011 | 05:47 PM
blackrocky's Avatar
What's up with nls and the problems behind it lol
Old Jan 13, 2011 | 05:52 PM
SSlobalt's Avatar
You're not supposed to use it with a tune.
Old Jan 13, 2011 | 06:03 PM
CudaJoe's Avatar
you know what funny?
About a year ago, anybody on this forum would have probably blamed the intake based on the OP.
blackrocky's Avatar
I rarely use it..........nls into 2nd is a no no if I was to use it.
Old Jan 13, 2011 | 08:09 PM
corn gas ftw....
i only nls 2-3 and 3-4, mostly just 3-4
turbochargedss2012
Sep 20, 2023 12:17 PM
717ssbalt
Oct 2, 2015 04:01 PM
riceburner
Sep 30, 2015 03:54 PM
DocSvensk
Sep 27, 2015 02:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
