My stupid blown up car thread
Old Mar 17, 2015 | 07:53 PM
  #101
Originally Posted by KonnerTomlinson
got the turbo on and the drain line is 1.20" too long. Went to have it shortened and they couldn't do it today because they're so busy. Hopefully tomorrow!
At least it wasnt short
Old Mar 17, 2015 | 08:31 PM
  #102
KonnerTomlinson's Avatar
that's true haha , I'm hoping to get it perfect
Old Mar 18, 2015 | 02:08 PM
  #103
Aaaaand they cut it too short. It's about 1/2 short and can't get onto both threads. Time to go back
Old Mar 18, 2015 | 02:25 PM
  #104
Son of a bitch, that blows
Old Mar 18, 2015 | 03:14 PM
  #105
girlfriend should be dropping her car off shortly so I can go up there and get a new line. Double checked and measured everything so this time should be perfect
Old Mar 18, 2015 | 08:11 PM
  #106
Perfect fit for the new drain line! Fired it up and after idling for 3 mins it started blueish white smoking. Shut it off and went inside pissed off I'm going to screw with it tomorrow and try to find the issue.
Old Mar 18, 2015 | 08:19 PM
  #107
You installed new pistons and rings right?
Old Mar 18, 2015 | 08:37 PM
  #108
yes I did
Old Mar 18, 2015 | 08:58 PM
  #109
Could it be initial blowby till the rings get seated better? I'm assuming your coolant temp was still low
Old Mar 19, 2015 | 07:14 AM
  #110
weirdly enough it didn't start smoking until temp got above 175
Old Mar 19, 2015 | 11:17 PM
  #111
kzak104's Avatar
when i first started my car up after i put the turbo on it smoke the shop out from all the cutting fluid in the exhaust and oil on the turbo to keep it from rusting, probably all it is, hold the idle up for a few minutes to burn the **** out, then take it for a good drive to seat the rings.
Old Mar 20, 2015 | 12:19 AM
  #112
it's definitely not normal. Oil is coming out of the turbo and dripping on the exhaust housing and then the ground. I attached a pic from sticking my arm under the car so it's not facing the right way but you can see the oil on the turbo
Old Mar 20, 2015 | 01:40 AM
  #113
kzak104's Avatar
Shiit. That sucks. Rebuilt turbo or?
Old Mar 20, 2015 | 11:00 AM
  #114
yep , I payed almost $1000 for it to be completely rebuilt. Still have my paperwork and everything. I just sent pics and info to Precision and they gave me a call and they're confused too. They want me to take it off and send it back again.
Old Mar 20, 2015 | 11:26 AM
  #115
Its not your oil feed or return line connection leaking it is?
Old Mar 20, 2015 | 12:22 PM
  #116
no it's coming out of where the CHRA meets the turbine housing
Old Mar 21, 2015 | 01:34 PM
  #117
I guess this is a common problem on precision turbos and they always blame install error. My drain is off and I let it drain into a bucket and it's pointing straight down and still leaks out the side. So it's not a issue with my return line it's obviously a rebuild issue from when they replaced all the gaskets/bearings and all.
Old Mar 23, 2015 | 01:03 PM
  #118
Turbo is coming off and being sent back go precision... Again. Wish this 6262 would just work!
Old Mar 23, 2015 | 02:07 PM
  #119
armcclure's Avatar
Surprised I just found this thread.
Sooner or later this car is bound to function properly !
Old Mar 23, 2015 | 02:51 PM
  #120
Damn. You just just supercharge it!
Old Mar 23, 2015 | 04:15 PM
  #121
Surprised I just found this thread. Sooner or later this car is bound to function properly !
I sure hope so! I'm glad you found it haha
Old Mar 23, 2015 | 04:16 PM
  #122
I like turbo noises too much. My inner ricer showing
Old Mar 25, 2015 | 09:35 PM
  #123
No word from precision yet , was supposed to be back Thursday but that would've meant they sent it out today. Hopefully they send it out tomorrow
Old Mar 30, 2015 | 12:15 PM
  #124
This car is bad luck , someone want to come drive over it in my driveway so I can claim insurance ?
Old Mar 30, 2015 | 01:09 PM
  #125
taintedred07's Avatar
You get the turbo back?
