Is my timing chain stretched?
Pulled my valve cover and I see this. Is the chain supposed to have this much slop with the motor off?
I pulled the timing cover about 6 months ago and the guides looked ok.
Something is probably wrong so I'm looking at this kit: More Information for CLOYES 94201SX
Can anybody vouch for its quality?
Is there a how-to available for this job?
That is still too much slack even with the tensioner at rest. Even without oil pressure the spring
in the tensioner should remove most of the slack you see there.
I personally haven't heard much about that kit but it looks identical to gm's guide and chain, down to the timing mark on the chain. personally im more for oem but either way I would do
a balance chain, tensioner, and guides while your in there.
Depends where the motor lands. If it stops where the cams are neutral, then some slack there is normal as the rest of the chain will be taut.
If you have some age on the car though, the chain could probably use replacement. They do stretch a little and the tensioners/guides aren't the best.
Unfortunately this was discovered as an afterthought. I opened up the valve cover because I was hearing a slight knocking / tapping noise, expecting to find broken rockers or lifters. So I wasn't paying much attention to the timing chain at the time. It dawned on me after that the chain didn't look right so I took a look at other LNF timing chains on Google images. So far, every image I have seen shows a taut chain.
The motor was definitely not at TDC when this was taken. Regardless, this still does not look right.
I have ordered the Cloyes kit and will replace everything for peace of mind.
Tips would be appreciated if you have any. What's the best approach to loosening the tensioner? There's like 0 room from the top.
