cel p2187
cel p2187
cel code bank 1 lean at idle.
hmmmm confused, car idles perfectly fine, ive read of people having this code at losing boost pressure. i havent lost boost pressure i peak at 24 and hold at 22psi. it has 44,301 miles and i havent ever had this problem, i know that the plugs havent been changed all my piping is tight with vband clamp. i havent noticed any hesistation other then when coming from a dead stop i need to give it a little gas to like 1200 rpms to get moving or else it gives a little shutter. plugs maybe? maf sensor maybe?
hmm
after visual inspection where the maf goes into the dejon intake it has to screws one is completely gone so its not completely sealed. this could be the problem, hence maybe its sucking in air thru that hole and the maf isnt readin that extra air............................ maybe help. im a mechanic by trade grr wish i could do some logging
My car just threw this code too....idk what it is...and it does the same thing at idle...shutters and ****....any idea what it could be caused from? I have my MAF relocated to my lower cp too and car is trifecta tuned
OP - If you have the Dejon intake, the fuel trims are whacked and you will need to get a good tuner to correct them. It must be the missing screw causing your issue or the gasket on the MAF is missing because I have to pull fuel at idle (too rich) and add fuel at WOT. Continue to check for boost leaks as well.
well im tuned for all my parts........
kinda just said **** it. fuel trims are perfect all around except at idle........this only happens when the car sits at idle for at least 15 20 minutes
You can tune the fueling at idle as well. MAF correction table is rpm vs. load based.
Re-bumping this old thread anyone figure out the true issue for this? I started a new thread. Having the same issue.
https://www.cobaltss.net/forums/2-0l...3/#post7647879
