cel p2187
Old Jan 18, 2011 | 04:10 PM
fl0wVdub's Avatar
cel p2187
cel code bank 1 lean at idle.
hmmmm confused, car idles perfectly fine, ive read of people having this code at losing boost pressure. i havent lost boost pressure i peak at 24 and hold at 22psi. it has 44,301 miles and i havent ever had this problem, i know that the plugs havent been changed all my piping is tight with vband clamp. i havent noticed any hesistation other then when coming from a dead stop i need to give it a little gas to like 1200 rpms to get moving or else it gives a little shutter. plugs maybe? maf sensor maybe?
Old Jan 18, 2011 | 04:24 PM
fl0wVdub's Avatar
hmm
after visual inspection where the maf goes into the dejon intake it has to screws one is completely gone so its not completely sealed. this could be the problem, hence maybe its sucking in air thru that hole and the maf isnt readin that extra air............................ maybe help. im a mechanic by trade grr wish i could do some logging
Old Jan 18, 2011 | 04:30 PM
Red_SS/TC's Avatar
I had this cel and I did the bypass tank with the vacuum lines and I havent seen the cel again.
Sorry didnt see you had a bov but that fixed my car when I had this cel.
Old Jan 18, 2011 | 07:37 PM
fl0wVdub's Avatar
code at
Well I did some logging and the code is being set at 750rpm at 91 degrees. My vaccum is at 27ihg
Old Feb 12, 2011 | 11:19 AM
07SSYellow's Avatar
Resident Post Whore/Troll
My car just threw this code too....idk what it is...and it does the same thing at idle...shutters and ****....any idea what it could be caused from? I have my MAF relocated to my lower cp too and car is trifecta tuned
Old Feb 12, 2011 | 11:24 AM
Iam Broke's Avatar
OP - If you have the Dejon intake, the fuel trims are whacked and you will need to get a good tuner to correct them. It must be the missing screw causing your issue or the gasket on the MAF is missing because I have to pull fuel at idle (too rich) and add fuel at WOT. Continue to check for boost leaks as well.
Old Feb 12, 2011 | 01:16 PM
07SSYellow's Avatar
I just had vince tune my car a few days ago.in colorado then I drove 1600 miles with no.problems back to seattle and now im having this issue
Old Feb 12, 2011 | 03:07 PM
fl0wVdub's Avatar
well im tuned for all my parts........ kinda just said **** it. fuel trims are perfect all around except at idle........this only happens when the car sits at idle for at least 15 20 minutes
Old Feb 12, 2011 | 03:38 PM
SSlobalt's Avatar
Sounds like a vac leak.
Old Feb 12, 2011 | 04:19 PM
Iam Broke's Avatar
You can tune the fueling at idle as well. MAF correction table is rpm vs. load based.
Old May 4, 2017 | 11:04 PM
Titler's Avatar
Re-bumping this old thread anyone figure out the true issue for this? I started a new thread. Having the same issue.
https://www.cobaltss.net/forums/2-0l...3/#post7647879
turbochargedss2012
Sep 20, 2023 12:17 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
