My Turbo turned into a Supercharger
Old Jul 23, 2012 | 04:57 PM
Cobe's Avatar
Cruising down the road like a normal.. Turn down my dirt road and go 15 mph and I get into my drive way and start revving my car not to bad only to like 3k just cause I love the noise and The first rev sounded like a ******* supercharger... I go down to my neibors driveway (payment) and do a second gear pull and I HAVE NO BOOST AND MY CAR WHINES LIKE A BISH! I took off the upper charge pipe and there is no oil at the bottom of it going into the intercooler.... There is a little bit at the top of the charge pipe right where it starts at the flexible piece and where the upper cp connects to the turbo.. not to much but enough to get on my finger... I have a soccer scrimmage in 1 and a half... is it okay to drive it very easily??
Old Jul 23, 2012 | 04:59 PM
Cobe's Avatar
Turbo seal???? I will have pictures and videos coming soon.... Just please let me know if i can drive it or not.... I will drive it very very easy to practice...
2009CobaltLT's Avatar
Im gonna go out on a limb and say no, not safe to drive
07LSJ's Avatar
your threads are epic....
Old Jul 23, 2012 | 05:05 PM
FasterIsBetter's Avatar
^^I know right! Can't even spell pavement right. Glad I have a collective mind for puzzles.
Old Jul 23, 2012 | 05:07 PM
AaronJ's Avatar
Why did you think it sounding like a supercharger was a good thing in the first place?
Dart_SI's Avatar
Any smoking? Hows your afr?
Old Jul 23, 2012 | 05:08 PM
umrdyldo's Avatar
Don't they usually blow smoke out the tail pipe is it's the turbo seals? You sure you don't have a major boost leak and you aren't hearing the turbo? It's super freaking loud. Ask me how I know.
Old Jul 23, 2012 | 05:09 PM
Cobe's Avatar
almost as epic as your lsj man. your the biggest piece of **** I know. I have soccer in a hour and need to know what the **** is wrong with my car. Not giving a flying f about spelling your a lsj get the **** out of the lnf category you piece of ****. I need information not replys from a dbag like you hahahaha like does that make you feel better? god your a ******* idiot.
Anyone else notice dirt road? OP are you sure you didn't scrape the intercooler on anything? It doesn't take much to break the stocker.
Old Jul 23, 2012 | 05:10 PM
Cobe's Avatar
white smoke was coming from the exhaust... and im not pushing over 0lbs....
Old Jul 23, 2012 | 05:11 PM
07LSJ's Avatar
are you sure you know what a sc sounds like? cuz dam, a turbo whining is not too common
umrdyldo's Avatar
We posted several possible things. Can you help us narrow and answer down?
And ****, its just a scrimmage. No need to fret unless you're the coach, lmao!
Cobe's Avatar
i didnt...
Old Jul 23, 2012 | 05:13 PM
Cobe's Avatar
white smoke comes out the exhaust when i rev... sounds like a sc not really like one but sounds like a sc more my damn turbo.. I dont go over 0lbs of boost and my vaccum is at like 12 untill i start to go then it goes back down to 20..
07LSJ's Avatar
ssyellow's Avatar
Longest run-on sentence everrrrrrrrrrrr
And white smoke is coolant. Bad news bear has arrived.
Old Jul 23, 2012 | 05:14 PM
kdub1492's Avatar
You asking for answers, but not giving us much to go off of. So before you become the dbag, give us some symptoms
Old Jul 23, 2012 | 05:15 PM
OP, jack up your car real quick, look at the bottom of the intercooler, see if theres a metal condenser there or if it looks like anything pushed up on the intercooler. Also check the lower charge pipe, make sure its connected on both ends.
07LSJ's Avatar
lmao
breds2k's Avatar
Good luck getting any help talking **** to people and asking for help *******. Your 16 and you have an LNF, im surprised you didnt blow it up sooner.
SUbd for laughs for days.
surfdude979's Avatar
White smoke sounds like a head gasket
Old Jul 23, 2012 | 05:16 PM
Cobe's Avatar
no just need answers... im varsity captain and this coulld be a bad look for me...
1.. white smoke when revving
2... dont go over 0lbs
3.. supercharge noise more then turbo noise.. even in reverse.
4... took of the charge pipe and there is oil where the charge pipe connects to the turbo.. enough to get some on my finger a couple times...
5.. no oil where upper connects to intercooler.
White smoke could be coming out of the exhaust cause you worked the turbo to death with a big ass boost leak. Check for busted/loose ****!
