My Turbo turned into a Supercharger
Old Aug 2, 2012 | 04:33 PM
  #426
AaronJ's Avatar
Originally Posted by Joe Schulte
In all fairness regarding the above, I don't relate the tune to the death of said turbo.
Mine and many other's have been making boost like that for quite a while.
I'm saying he still shouldn't run the tune after he changes the turbo. Its basic trouble shooting / problem solving. When windows starts crashing, you do a system restore to a point before you made your most recent changes to the OS to see if that fixes the problem. If it doesn't fix it, then it was something else, but if it does fix it then you would look more closely at the changes you made to see if you can pinpoint exactly what's causing the problem.
I didn't say the tune was the reason his turbo blew up. As of right now, nobody can prove that the tune blew up the turbo, but at the same time nobody can prove that the tune didn't blow up the turbo. If it is the tune, it doesn't have to be the level of boost that did it, I'm sure there are many different variables. The point is, he should return the car to the last state that it was running fine in, and start to work his way forward again from there, eliminating things one by one.
Old Aug 3, 2012 | 12:23 AM
  #427
Cobe's Avatar
So your boost Jumps around after 5k too??
PICKED UP A NEW KO4 TONIGHT FROM DEMON2003 THANKS!
Now we're getting some where
Old Aug 3, 2012 | 08:30 AM
  #428
user 72239's Avatar
Cobe you should of put an M62 on that bitch. **** a k04
Old Aug 3, 2012 | 09:13 AM
  #429
CudaJoe's Avatar
dont listen to him, K04 is be all end all next to a M62. go install your turbo and get the car retuned to a safer boost.
Old Aug 3, 2012 | 10:49 AM
  #430
Cobe's Avatar
Old Aug 6, 2012 | 10:45 AM
  #431
Cobe's Avatar
If the turbo came off of a LNF and is slightly used.... Do I need to worry about the waste gate being adjusted?... or Do I need to worry about anything or do anything special while doing this?
Old Aug 6, 2012 | 11:24 AM
  #432
CudaJoe's Avatar
You should be fine to just put it on. Wastegate shouldnt need to be adjusted, unless your not building boost..
Old Aug 6, 2012 | 11:35 AM
  #433
Cobe's Avatar
Okay I hope to do this today. Ill keep up on the swap
*Might make a how to because there isnt a good one on here with pictures*
Old Aug 6, 2012 | 12:15 PM
  #434
bignicky1's Avatar
Ohh this brighten my Monday up so much thanks cobe!
Old Aug 6, 2012 | 01:02 PM
  #435
Cobe's Avatar
and the LSJ sorry video should be coming soon next week sometime (: big surprise haha
Old Aug 7, 2012 | 11:05 PM
  #436
Cobe's Avatar
Guys what do I do with my wastegate settings? The turbo came off of a LNF so it should be alright??? Ccss3 said turn it all the way to the right... Which I don't doubt him but I'm asking everybody!
Old Aug 7, 2012 | 11:07 PM
  #437
kdub1492's Avatar
shouldnt need to be adjusted, but yes to the right if need be
Old Aug 7, 2012 | 11:20 PM
  #438
Cobe's Avatar
Like all the way to the right??? It's in the middle now
Old Aug 7, 2012 | 11:22 PM
  #439
Cobe's Avatar
Just like my one I'm taking off
  #440
Stamina's Avatar
Usually mine tends to hang a little to the left.
Old Aug 7, 2012 | 11:25 PM
  #441
Cobe's Avatar
What??? What does that even mean?! And should I buy a metal gasket like the one that came off?? It looks fine and it's metal... So should I have too? 39x miles on car
Old Aug 7, 2012 | 11:27 PM
  #442
Stamina's Avatar
I'm just messing with you man. When I saw those comments it sounded like you guys were talking about something completely different. hahaha
Old Aug 7, 2012 | 11:34 PM
  #443
Cobe's Avatar
Ahhhh your a jokester hahaha
Okay so anyone?? Leave the waste gate alone?
Old Aug 8, 2012 | 01:55 AM
  #444
FasterIsBetter's Avatar
I'd leave it alone and yes, you need to buy atleast 2 new gaskets. They are all the same part number I believe, theres one on the O2 housing to the side of the turbo, one on the turbo manifold to turbo, and one on the downpipe to O2 housing flange. Thats 3 gaskets.
Old Aug 8, 2012 | 10:21 AM
  #445
Cobe's Avatar
Alright leavin wastegate alone and putting new gaskets and rtv on today and turbo will be in by tonight also... Also two-a-days started for soccer at 8am so I ran 7 miles this morning in today's first session... My ass is kicked!
Also what will happen if my hoses for the stock boost controller are backwards?? I know the one going to ye waste gate it correct and ccss3 said I had the other two wrong so I swapped them to the correct position.. What would of happened if I wouldn't have?
Old Aug 8, 2012 | 10:46 AM
  #446
CudaJoe's Avatar
flutter noises.
Old Aug 8, 2012 | 11:23 AM
  #447
Stamina's Avatar
Hook it up like this:
Old Aug 8, 2012 | 02:12 PM
  #448
SSlobalt's Avatar
Old Aug 8, 2012 | 02:15 PM
  #449
Stamina's Avatar
...and there you have it, sir. ^
Old Aug 8, 2012 | 02:45 PM
  #450
breds2k's Avatar
Now thats what a forum should be about! Helping words/pictures instead of ****y comments.....
(insert not sure if serious on cobalt forum meme here)
