need help!!
Old Mar 23, 2011 | 07:14 PM
turbo_chevy_cobalt's Avatar
need help!!
I was getting p2187 and p2261 two days ago. It running real bad at idle but if i drive it it seems ok. I found out i had a o2 sensor loss. Thightened that and still running bad at idle. Next i looked for any boost leak cant find any. I disconnect maf and it seems to run smooth. So put new maf in and it didnt fix it. Now when i start it i just get misfires. Changed coils didnt help. So i tried something and opened the bov by hand and that makes run smooth at idle. Any help will work. no blow by also
Old Mar 23, 2011 | 07:24 PM
Sweetsandman's Avatar
What type of BOV are you running? And is it recirculated since you aren't running a blow-by setup?
Old Mar 23, 2011 | 07:30 PM
turboxs to atmosphere. no blow by as in compression is all good. i been running fine till two days ago and i didnt change a thing till today.
Old Mar 23, 2011 | 07:32 PM
Do you have a MAF relocate?
Old Mar 23, 2011 | 07:37 PM
nope
Old Mar 23, 2011 | 07:41 PM
i have had a boost leak like a year ago due to intercooler it not acting the same as when the leak happened.
Old Mar 23, 2011 | 07:42 PM
nope
Hmm...well if you manually opened the BOV and everything ran fine. I'd say your BOV is out of order. Is there a stronger spring available for it?
Old Mar 23, 2011 | 07:45 PM
i can put spacers in it but still didnt help i even took all of the spacers out didnt help.
Old Mar 23, 2011 | 07:55 PM
tomj77's Avatar
replace #1 02 sensor
Old Mar 23, 2011 | 08:14 PM
lol just did that no difference. i havent had this hard of a time to find the problem.
