need help ASAP with car being all weird!!
Old May 29, 2010 | 07:16 PM
cardelino18's Avatar
Question need help ASAP with car being all weird!!
ok so the car wont star up.... the inside gauges are all "ticking", especially the boost gauge... it goes from 0-over the 30 psi mark back and forth... it feels like there is no spark but the spark plugs are new... what the hell can i do to fix it?!?!?!?!??!?!?!
thanks!
Old May 29, 2010 | 07:23 PM
DGAF260's Avatar
no start or no crank
Old May 29, 2010 | 07:27 PM
SSlobalt's Avatar
Man, you guys are having a hella hard time with that motor replacement.
Old May 29, 2010 | 07:32 PM
pt5457balt's Avatar
THis was happening on my car before we found out the electrical system wasn't grounded right.
Not sure that helps at all, but it's what we ran into. Possibly the starter wires are crossed (if that's possible(?
Old May 29, 2010 | 07:43 PM
SSlobalt's Avatar
Ground: (photo by Gestapo)
Old May 29, 2010 | 08:09 PM
thats the hot or cold side charge pipe??
Old May 29, 2010 | 08:11 PM
Chevycobaltss3's Avatar
On my sssc' I ran into thesam ordeal my buddy put my connection on wrong
Old May 29, 2010 | 08:14 PM
EdCobaltSS's Avatar
check if the battery is charged! That is one of the signs of a semi-dead battery on our cars
Old May 29, 2010 | 08:16 PM
SSlobalt's Avatar
That's the hotside.
Old May 29, 2010 | 09:57 PM
HHRSSouth's Avatar
First thing I thought after reading the OP, bad ground somewhere.
Old May 30, 2010 | 12:10 AM
It cranks but it won't start and a couple of days ago it started and it ran but the ideling was bad so he re did the timing and it turned on great and everything but 10 minutes later it died...I changed the crankshaft sensor but it just won't turn on now
Old May 30, 2010 | 01:49 PM
pt5457balt's Avatar
Now it sounds like your timing is still off.
Old May 30, 2010 | 02:13 PM
It sounds like it a chevorlet now ha jk, it sounds like a loose ground
Old May 30, 2010 | 07:26 PM
ok i just checked and my car does not have that cable that goes from the starter to the chasis... is that too bad or i need one there?
Old May 30, 2010 | 07:38 PM
Berto09ss's Avatar
yeah you'll need to ground it bro
Old May 30, 2010 | 09:33 PM
Matt M's Avatar
Why would you be missing a ground cable? It doesn't need to be removed from the car to pull the engine. BTW, it doesn't hook to the starter- it is connected to a stud on the trans. Also, make sure that the smaller ground shown in the pic is not hooked to the starter B+ post.
Old May 31, 2010 | 01:06 AM
ooo ok so it was right... so what could it be!?!?!
The Rookie24
Jan 20, 2016 05:14 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
Cobe
Sep 19, 2015 11:04 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
soundjunky
Sep 3, 2015 01:18 PM
