need some help 2.0 turbo
Old Aug 3, 2011 | 06:07 PM
chevyrider09ss's Avatar
anyone got a how to for head removal??? i kinda need some guidance on this as i fucked up my head and i need to change it out. lol and i ship my car out on august 23rd. im cutting close lol.
Old Aug 3, 2011 | 06:08 PM
07SSYellow's Avatar
Resident Post Whore/Troll
just start pulling bolts! haha
j/k ive never done it but im sure someone will stop in and help u
Old Aug 3, 2011 | 06:12 PM
hahaha im about to lol losing my mind now im about to start right now its 12:11am and i have to be up for PT formation at 6. could be an all nighter right now.
Old Aug 3, 2011 | 06:17 PM
07SSYellow's Avatar
haha were are u at?
Old Aug 3, 2011 | 06:21 PM
germany as of now. lol home for good in oct.
Old Aug 3, 2011 | 06:23 PM
07SSYellow's Avatar
nice nice lol well good luck bro
JustACobalt's Avatar
hope this isnt illegal lol oh yeah ur welcome
Cylinder Head Replacement
Special Tools
* EN 46101 Spark Plug Tube Seal Guide
* EN-48953 Camshaft Actuator Locking Tool
* J 38185 Hose Clamp Pliers
* J 45059 Angle Meter
Removal Procedure
1. Drain the cooling system. Refer to Cooling System Draining and Filling (GE 47716 Fill) (See: Cooling System\Service and Repair)Cooling System Draining and Filling (Static Fill LNF) (See: Cooling System\Service and Repair)Cooling System Draining and Filling (Static Fill LE5, L61) (See: Cooling System\Service and Repair).
2. Remove the exhaust manifold. Refer to Exhaust Manifold Replacement (LAP) (See: Exhaust System\Exhaust Manifold\Service and Repair)Exhaust Manifold Replacement (LNF) (See: Exhaust System\Exhaust Manifold\Service and Repair).
3. Remove the intake manifold. Refer to Intake Manifold Replacement (See: Intake Manifold\Service and Repair).
4. Reposition the radiator surge tank air bleed hose clamp.
5. Remove the radiator surge tank air bleed hose from the cylinder head.
6. Reposition the radiator inlet hose clamp using the J 38185 .
7. Remove the radiator inlet hose from the cylinder head.
8. Disconnect all electrical connectors as necessary.
9. Remove the camshaft cover. Refer to Camshaft Cover Replacement (See: Valve Cover\Service and Repair).
10. Remove the upper timing chain guide bolts and guide.
Note: If the intake camshaft actuator is moving independently of the camshaft, this means the camshaft is not locked to the actuator. Rotate the camshaft counter-clockwise while the holding tool is installed and this will lock the camshaft to the actuator.
Note: Ensure the timing chain and the camshaft position actuators are marked for proper assembly.
11. Rotate the intake camshaft clockwise and install the EN-48953 (1) to the actuators. Caution: Refer to Fastener Caution (See: Service Precautions\Vehicle Damage Warnings\Fastener Caution).
12. Install the camshaft actuator retainer bolts and tighten to 10 Nm (89 lb in) .
13. Clean the timing chain and gears with solvent.
14. Mark the timing gear sprockets and the timing chain. It is recommended that the paint marks are located in the 12 o'clock position.
15. Loosen, but do not remove the intake and exhaust camshaft actuator bolts.
16. Remove the camshaft actuator locking tool, EN-48953 .
Note: Ensure the tips of the EN-48749 are fully engaged into the timing chain. The retention tool rod can be used on the back side of the chain to ensure the teeth from the retention tool are engaged.
17. Install the timing chain retention tool EN-48749 (1) to the intake side of the timing chain.
18. Remove the timing chain tensioner.
Note: The camshaft actuators should not rotate during the removal of installation.
19. Install the timing chain retention tool EN-48749 (1) to the exhaust side of the timing chain.
20. Remove and discard the exhaust camshaft actuator bolt (2).
21. Remove and discard the intake camshaft actuator bolt (2).
22. Remove the intake camshaft actuator (3) from the camshaft while also removing the actuator from the timing chain.
23. Mark the cylinder head (1) in relationship to the camshaft actuator notch is on the camshaft (2).
24. Remove the fixed timing chain guide access plug.
Note: The threaded rod from the timing chain retention tool can be used to help feed the rubber band around the chain guides.
25. Install a rubber band (1) around the top of the upper timing chain guides (2) in order to pull the guides together.
26. Remove the cylinder head bolts in the sequence shown. Discard the bolts.
27. Remove the cylinder head.
28. Remove the cylinder head gasket.
29. Clean all of the gasket surfaces.
30. Use the following steps when cleaning the cylinder head and cylinder block surfaces:
o Use a razor blade gasket scraper to clean the cylinder head and cylinder block gasket surfaces. Do not scratch or gouge either surface.
Note: DO NOT use any other method or technique to clean these gasket surfaces.
* Use a NEW razor blade on the cylinder head and a NEW blade on the cylinder block.
Note: Be careful not to gouge or scratch the gasket surfaces. DO NOT gouge or scrape the combustion chamber surfaces. The feel of the gasket surface is important, not the appearance. There will be indentations from the gasket left in the cylinder head after all of the gasket material is removed. These small indentations will be filled in by the NEW gasket.
* Hold the razor blade as parallel to the gasket surface as possible.
31. Clean the old sealer/lube and any dirt from around the bolt holes. Note: DO NOT use a tap to clean the cylinder head bolt holes.
32. Clean the bolts holes with a nylon bristle brush.
33. When cleaning the cylinder head bolt holes use suitable commercial spray liquid solvent and compressed air from an extended-tip blow gun in order to reach the bottom of the holes.
34. If replacing the cylinder head, transfer all parts as necessary.
Installation Procedure
Note: DO NOT use any sealing material.
1. Install the cylinder head gasket.
2. Install the cylinder head.
3. Install NEW cylinder head bolts.
4. Install and tighten the cylinder head bolts in the sequence shown. Tighten the bolts to 30 Nm (22 lb ft) plus an additional 155 degrees using the J 45059 .
5. Install the NEW front cylinder head bolts and tighten to 35 Nm (26 lb ft) .
6. Ensure the cylinder head (1) and the camshaft (2) are correctly aligned.
7. Remove the rubber band (1) from around the top of the upper timing chain guides (2).
8. Install the fixed guide bolt into the cylinder head and tighten the bolts to 12 Nm (106 lb in).
9. Apply sealant compound to thread and install the timing chain guide bolt access hole plug. Refer to Adhesives, Fluids, Lubricants, and Sealers (See: Specifications\Adhesives, Fluids, Lubricants, and Sealers) for the correct part number.
10. Install the fixed timing chain guide access plug and tighten to 90 Nm (59 lb ft) .
Note: Ensure that the alignment mark made previously on the exhaust camshaft actuator is still aligned properly with the mark on the timing chain.
11. Install the timing chain onto the intake camshaft actuator.
12. Align the intake camshaft actuator alignment mark made previously with the timing chain mark and install the actuator onto the camshaft.
13. Install a NEW intake camshaft actuator bolt (2) until snug.
14. Remove the timing chain retention tool EN-48749 (1) from the intake side of the timing chain.
Note: Ensure that the alignment mark made previously on the intake camshaft actuator is still aligned properly with the mark on the timing chain.
15. Install the timing chain onto the exhaust camshaft actuator.
16. Align the exhaust camshaft actuator alignment mark made previously with the timing chain mark and install the actuator onto the camshaft.
17. Install a NEW exhaust camshaft actuator bolt (2) until snug.
18. Remove the timing chain retention tool EN-48749 (1) from the exhaust side of the timing chain.
19. Reset and install the timing chain tensioner. Refer to Timing Chain Tensioner Replacement (See: Timing Chain Tensioner\Service and Repair).
20. Install the EN-48953 (1) to the actuators.
21. Install the camshaft actuator locking tool bolts and tighten to 10 Nm (89 lb in) .
22. Tighten the NEW camshaft actuator bolt and tighten to 85 Nm (63 lb ft), plus an additional 30 degrees using the J 45059 .
23. Release the tension by applying a counterclockwise torque on the harmonic balancer bolt then tighten the bolt to 45 Nm (33 lb ft) .
24. Remove the camshaft actuator locking tool, EN-48953 .
25. Install the upper timing chain guide bolts and guide and tighten the bolts to 10 Nm (89 lb in) .
26. Install the camshaft cover. Refer to Camshaft Cover Replacement (See: Valve Cover\Service and Repair).
27. Connect all electrical connectors as necessary.
28. Install the radiator inlet hose to the cylinder head.
29. Position the radiator inlet hose clamp using the J 38185 .
30. Install the radiator surge tank air bleed hose to the cylinder head.
31. Position the radiator surge tank air bleed hose clamp.
32. Install the exhaust manifold. Refer to Exhaust Manifold Replacement (LAP) (See: Exhaust System\Exhaust Manifold\Service and Repair)Exhaust Manifold Replacement (LNF) (See: Exhaust System\Exhaust Manifold\Service and Repair).
33. Install the intake manifold. Refer to Intake Manifold Replacement (See: Intake Manifold\Service and Repair).
34. Fill the cooling system. Refer to Cooling System Draining and Filling (GE 47716 Fill) (See: Cooling System\Service and Repair)Cooling System Draining and Filling (Static Fill LNF) (See: Cooling System\Service and Repair)Cooling System Draining and Filling (Static Fill LE5, L61) (See: Cooling System\Service and Repair).
Old Aug 3, 2011 | 06:25 PM
07SSYellow's Avatar
haha hells ya!! there u go bro
Old Aug 3, 2011 | 06:34 PM
thanks man im gonna get on this asap and order this new head. i appriciate this.!! sounds a lil difficult but hopefully not to bad.
Old Aug 3, 2011 | 07:10 PM
no problem man good luck!
Old Aug 3, 2011 | 08:34 PM
Ch1ck3n's Avatar
Can always check out Chilton or a Haynes manual too.
Old May 30, 2014 | 08:48 AM
dcrep06's Avatar
holy **** ***** thats a lot lol. im gonna be replacing my head and timing chain this weekend. is there any need to follow these removal steps? or can i just pull it all off? have a bad feeling im gonna need to replace the block as well i sure hope not though lol.
Supercharged06SS
Dec 11, 2022 04:47 PM
HEATON
Oct 16, 2015 07:21 PM
maliki778
Oct 1, 2015 07:39 PM
Sep 28, 2015 12:51 PM
