Need some help with ID of this part
Old Aug 27, 2012 | 08:49 PM
JetLAGG's Avatar
A post a while back, I was trying to figure out why my exhaust was so damn loud. So I checked it out before and it look somewhat normal to me. Didn't care at the time since the car ran fine. But today I decided to really get under it at Sears and I looked underneath Roxxy and this what I found....
Dude, what is this? Couldn't get to see the downpipe and it's probably catless sense I couldn't see the converters on the dp at all. The part looks relatively new, but I don't know what maker it is from nor if its a custom made one.
Any input would be appreciated...
Old Aug 27, 2012 | 08:55 PM
ultimategnar's Avatar
has the same flex pipe as my zzp dp a angled o2 bung probally zzp
BLAZIN07SS's Avatar
I'm too JDM for you
Megan racing 3 inch catless downpipe
Old Aug 27, 2012 | 08:58 PM
SSlobalt's Avatar
this
Old Aug 27, 2012 | 09:01 PM
JetLAGG's Avatar
this does look like it, but should I just leave it on or swap it out. The last 2 parts that connect to the muffler was taken off. The rest is stock muffler and some other old pipe.
SN: Not a fan of megan exhaust. They seem extremely ricey to me.
Old Aug 27, 2012 | 09:10 PM
SSlobalt's Avatar
If you want it quieter and legal, buy a ZZP catted downpipe.
Old Aug 27, 2012 | 09:12 PM
JetLAGG's Avatar
I could care less about the sound really, it's the performance aspect of it. Haven't heard to much info on megan. Is it easy just to add a different makers parts to replace the the stock muffler and old pipes?
Old Aug 27, 2012 | 09:17 PM
SSlobalt's Avatar
The stock catback is not restrictive. The only gain you'll get is sound. Spend your money on something else.
Old Aug 27, 2012 | 09:19 PM
JetLAGG's Avatar
Basically, just get a whole new exhaust?
Old Aug 27, 2012 | 09:22 PM
SSlobalt's Avatar
I don't understand what you're asking, I don't think. The exhaust you presently have is fine. If you're ok being catless, that's the way to make the most power.
Old Aug 27, 2012 | 09:25 PM
jacream_booSSted's Avatar
i think that's what he's saying lol. i'm not sure either.
Old Aug 27, 2012 | 09:29 PM
JetLAGG's Avatar
Ok....my fault for confusing you. I'm guessing what your trying to say is this part doesn't do anything, except make more noise. My question is, should I just sell the part and buy full catless exhaust instead? I know some makers like borla, magnaflow, and etc. have made exhausts that produce power while catted, I believe. Should I go with those makers or just say screw it all and go straight pipe with catless dp?
Old Aug 27, 2012 | 09:36 PM
BLAZIN07SS's Avatar
I'm too JDM for you
The Megan is fine. It's a 3 inch piece of pipe just like all the others. I really wouldn't worry about it. Many members have 10's of thousands of miles on their parts
Old Aug 27, 2012 | 10:04 PM
FasterIsBetter's Avatar
You are currently full catless. There are no cats left in your exhaust....
Old Aug 27, 2012 | 10:11 PM
JetLAGG's Avatar
If that is true....my ass will never pass inspection in MD....smh
Old Aug 27, 2012 | 10:17 PM
BLAZIN07SS's Avatar
I'm too JDM for you
If its only a obd2 inspection and not visual, there are easy ways around it. As long as the readiness tests are completed and no codes set, you're fine
Old Aug 27, 2012 | 10:18 PM
reaper89's Avatar
If you have a visual and pass obd test, then weld a shell on there
Old Aug 28, 2012 | 08:11 PM
JetLAGG's Avatar
MMMmmm....or just deal with it in the next 2 years. lol Anyways, my other question right now is this: I want to get the gms1 kit BUT with the current parts on the car (K&N SRI installed by me, catless exhaust came with car), will it be safe to run on the long run (its my DD)? Will I have to get a new upper CP and intercooler?
Talked to a friend of mind and said that it will probably need it because with his hp tune and catless, his intercooler went to **** and stock cp cracked. Also he was hitting 26 psi ( I think, ask him tomorrow) and he pumping out 320+ hp.
Old Aug 28, 2012 | 09:09 PM
SSlobalt's Avatar
Stock intercoolers are trash. I gave up after my third one.
Old Aug 29, 2012 | 07:49 AM
CudaJoe's Avatar
Yea dude, I pass inspection just fine.
Old Aug 29, 2012 | 11:36 AM
JetLAGG's Avatar
Thats good to know. I just wonder why it's throwing a CEL???
Old Aug 29, 2012 | 12:17 PM
09CobaltSS1's Avatar
The downstream o2 needs to be disabled in the tune when you're catless. Even with a defouler on there you will eventually throw some sort of dtc.
Old Aug 29, 2012 | 12:33 PM
Balt_and_Vette's Avatar
your more than likely getting a p0420 because your catless. I have to clear mine every time I drive it which is super annoying. I'm in the process of being tuned and it's getting disabled.
Old Aug 29, 2012 | 02:59 PM
JetLAGG's Avatar
I mean its not showing CEL at all. Ever since I bought it, no codes at all instead of the evap.
Old Aug 29, 2012 | 03:51 PM
Maybe you still have a tune on it but just a mild one? If 'm getting 0420 and I have a high flow cat, angled bung, and a de-fouler there is no way in hell you wouldn't get one if your totally catless and no de-fouler.
