Needing some help
Old Jan 27, 2012 | 05:15 PM
HyperFocus's Avatar
Needing some help
bolt to the condensation catch dissappeared
Old Jan 27, 2012 | 05:21 PM
05Slowline's Avatar
condensation catch shouldn't effect anything i think people have taken them completely off
Old Jan 27, 2012 | 05:25 PM
HyperFocus's Avatar
oh ok, thanks, i wasnt sure of its purpose..what is it held on by?
Old Jan 27, 2012 | 06:11 PM
tomj77's Avatar
u would be wise to get rid of that stock crap with plastic end tanks and get a proper ic
Old Jan 27, 2012 | 06:25 PM
HyperFocus's Avatar
i just took it off for now, weight reduction FTW haha.. and yeah im aware that the intercooler sucks, its in my future modding plans..im all stock now though. i have no idea what couldve happened to the bolt that holds in in haha, the one on the other side was tight as hell
Old Jan 27, 2012 | 07:03 PM
iLikeBoost's Avatar
My condensation did the same thing, just randomly one day. I heard a noise while crossing rail road tracks, I pull over to see whats up and theres the catch just hanging there by one side. Thankfully the rail road tracks didn't tear it off and crack my IC.
Anyway, I took the catch off, and used JB Kwik to fill the holes on the bottom of the IC where the catch plugged in. I've been driving it like that for about 15k miles and have had no problems.
Old Jan 27, 2012 | 07:34 PM
HyperFocus's Avatar
glad you didnt crack your IC! thanks for the tip, might try some of that stuff..got another screw to put it back on but might just leave it off alltogether
Old Jan 27, 2012 | 07:57 PM
SSlobalt's Avatar
You need to fill the holes with JB Weld, if you're cracked in that area. Depends on how it's broken. You can do a boost leak test to confirm, or if you find yourself running like crap, fill the holes.
Old Jan 27, 2012 | 09:05 PM
HyperFocus's Avatar
its not broke anywhere, the screw just fell out on one side..and thankfully no boost leak
Old Jan 27, 2012 | 09:50 PM
SSlobalt's Avatar
Did you run a boost leak test? You might still have a leak from one of the small holes in the pic. I bought a metal IC, so I never bothered with removing that thing, but maybe someone else with experience with this can tell you for sure if you need to seal those holes. I think there's one in the bottom of the bolt channel, too. The bolt has an o-ring underneath it as well as the red o-ring you see, so those might be pressure seals, and not condensation seals.
Old Jan 27, 2012 | 11:36 PM
HyperFocus's Avatar
thanks for the info ^^
Old Jan 28, 2012 | 12:31 AM
nobody2u's Avatar
Aside from the plastic end caps, the stock IC isn't bad. Especially since most aftermarket ICs weigh quite a bit more.
Old Jan 28, 2012 | 03:21 PM
SSlobalt's Avatar
You won't get any agreement from me on that.^ It went through 3 of the stock IC's on stock boost. I got so tired of worrying about it cracking and leaving me on the side of the road that I broke down and bought the ZZP IC. Of course, since I had to replace a stock part with an aftermarket part, my dealership will use that as an opportunity to deny any type of warranty claim on the engine. Oh well, I'd rather have the peace of mind that comes with knowing my car won't be on the side of the road after letting off the throttle on a WOT burst.
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
