Negative Boost at idle
OK,so normally when my car is idling after I first start her up the scan gauge reads -21.6psi or around there.
Recently in the past few days its been sitting at -17.9psi. Theres been no weather change.
Any idea whats going on here ?
do you have your defrosters on by any chance? The defrosters kick the A/C compressor on which will cause you to lose a little bit of vacuum due to the slight load running the compressor puts on the engine. A/C running at idle generally registers about 17inHG. (that's inches of mercury and not so much a negative psi btw)
i take it this is your first turbocharged car
you may not think that there's been any "change in the weather", but even slight changes in humidity, barometric pressure, and temperature, can cause your car to make adjustments.
Ok we got the joke about the negative boost f'in idiots, stop rubbing it in, like half of you douches are experts anyway. You never see any of these experienced tuners on her laughing at your nonsense. It's his first turbo car, he doesn't know.
Take the car to kevin for the tuning issues you are experiencing. He is good. He had worked on all kinds of problem cars and solved them.
Trust me, take the plunge. I'll be going to see him come april. You could join.
Cheers.
Cheers.
Cheers.
Cheers.
and don't worry about the flaming, i had my fair share when i first started modding cars
I really thought this thread was a joke at first and people started actually responding to it... Alot of people do not realize the car is in vacuum when in idle its ok. My friend whos had a turbo car for over a year finally got a boost guage. When it lit up he was extremely concerned that something was wrong since it was his first time seeing vaccum and boost on an anolog in his car. kinda funny how hard he over reacted. lol.
Cheers.
Cheers.
Anyone who traps a measly 104 with a tune should probably keep their mouth shut
He has had a history of tuning problems with his car that he is going to get fixed, look at his previous posts
The AC compressor can affect vacuum, I agree, but other things can affect it as well.
he know a bit more about my car then most on here,I have been having some other issues with boost.I dont think there related with this issue,but ill look into it. Thanks anyways guys
