Negative Boost at idle
Old Oct 26, 2010 | 09:54 AM
superbrowndude's Avatar
OK,so normally when my car is idling after I first start her up the scan gauge reads -21.6psi or around there.
Recently in the past few days its been sitting at -17.9psi. Theres been no weather change.
Any idea whats going on here ?
Old Oct 26, 2010 | 10:06 AM
efactor's Avatar
check your wastegate underneath your car where the downpipe and turbo manifoldis located. make sure its not loose.
Old Oct 26, 2010 | 10:11 AM
Would I hear any kind of boost leak ?
Old Oct 26, 2010 | 12:40 PM
09CobaltSS1's Avatar
do you have your defrosters on by any chance? The defrosters kick the A/C compressor on which will cause you to lose a little bit of vacuum due to the slight load running the compressor puts on the engine. A/C running at idle generally registers about 17inHG. (that's inches of mercury and not so much a negative psi btw)
Old Oct 26, 2010 | 01:39 PM
kidcrash603's Avatar
LOL @ "negative boost"....
it's called vacuum.
Old Oct 26, 2010 | 01:41 PM
BlackJackSS's Avatar
i LOLd soooo hard at this thread
ssblackstealth's Avatar
corn gas ftw....
it's called vacuum.
hahaha this^^^^^!!!!
Old Oct 26, 2010 | 03:26 PM
Thats without the defroster on
Old Oct 26, 2010 | 03:30 PM
JacBlackSS/TC's Avatar
nothing is wrong with your car you are just in vacuum
i take it this is your first turbocharged car
Old Oct 26, 2010 | 05:07 PM
Yah it is. Im just curious why the vacuum would change like that after 6 months of sitting around -21ish ?
Old Oct 26, 2010 | 09:18 PM
you may not think that there's been any "change in the weather", but even slight changes in humidity, barometric pressure, and temperature, can cause your car to make adjustments.
Old Oct 26, 2010 | 09:24 PM
tomj77's Avatar
let it sit a little longer, it will get to -21. lol ur car is fine
Old Oct 26, 2010 | 09:32 PM
army_greywolf's Avatar
technically there is no such this as negative boost, or negative pressure.
Atmospheric pressure is just about 15psi @sealevel.
Old Oct 26, 2010 | 09:54 PM
raver0789's Avatar
Ok we got the joke about the negative boost f'in idiots, stop rubbing it in, like half of you douches are experts anyway. You never see any of these experienced tuners on her laughing at your nonsense. It's his first turbo car, he doesn't know.
Take the car to kevin for the tuning issues you are experiencing. He is good. He had worked on all kinds of problem cars and solved them.
Trust me, take the plunge. I'll be going to see him come april. You could join.
Cheers.
Old Oct 27, 2010 | 12:09 AM
tomj77's Avatar
Cheers.
he isnt having any tuning issues, his car is fine.
Old Oct 27, 2010 | 11:27 AM
yeah thats true the weather does affect your boost outputs, the car trues to compensate for the difference
and don't worry about the flaming, i had my fair share when i first started modding cars
Old Oct 27, 2010 | 01:13 PM
CudaJoe's Avatar
I really thought this thread was a joke at first and people started actually responding to it... Alot of people do not realize the car is in vacuum when in idle its ok. My friend whos had a turbo car for over a year finally got a boost guage. When it lit up he was extremely concerned that something was wrong since it was his first time seeing vaccum and boost on an anolog in his car. kinda funny how hard he over reacted. lol.
Old Oct 27, 2010 | 01:35 PM
troyss's Avatar
Cheers.
Wow really? Tuning issues? Don't listen to this guy hear he obvioulsy doesn't know what the hell he's talking about... Your car is fine and has no problem. It is normal for your car to do this at Idle so no need to take it to the almighty KEVIN
Old Oct 27, 2010 | 01:40 PM
ya raver0789 is a douche
Old Oct 27, 2010 | 01:55 PM
raver0789's Avatar
Anyone who traps a measly 104 with a tune should probably keep their mouth shut
He has had a history of tuning problems with his car that he is going to get fixed, look at his previous posts
The AC compressor can affect vacuum, I agree, but other things can affect it as well.
Old Oct 27, 2010 | 01:56 PM
CudaJoe's Avatar
ROFL. I trap 104 stock. Nobody traps 104 with a tune. They trap 108 or higher at least.
Old Oct 27, 2010 | 02:27 PM
troyss's Avatar
Guys learn a good lesson from Raven and the lesson is don't smoke crack...
This guys car is NORMAL raven NORMAL NORMAL....
Old Oct 27, 2010 | 03:22 PM
Thanks Raver and to anyone else that contributed useful information....Most of you guys are fucked...
Old Oct 27, 2010 | 03:27 PM
troyss's Avatar
How was Raven being usefull? By telling you a lie? Saying your having tunning issues when your NOT? You both don't need to be near 10ft of any car IMO.
Old Oct 27, 2010 | 05:03 PM
he know a bit more about my car then most on here,I have been having some other issues with boost.I dont think there related with this issue,but ill look into it. Thanks anyways guys
