Never put regular oil in your cobalt.
Old Jan 4, 2014 | 07:35 AM
  #51
Pitbull2o08's Avatar
Originally Posted by m33pm33p
^^this new cars are designed to be driven right away once out of cold start.
What is cold start?? Is that the same thing as closed loop?
Old Jan 4, 2014 | 10:46 AM
  #52
wayfarer's Avatar
*technically* "cold start" is anything lower temperature than desired operating temperature.
since I don't know the oil temp in my cobalt (I don't have an oil temp gauge) I use water temp -- I don't put my car in gear until the water temp is 100 degrees (F)
but I don't boost until 170
to the poster that said "oil doesn't affect fuel mileage" ---it can. conventional oil has greater viscous friction than synthetic. Look at the API circle on various oils for the "resource conserving" mark, and read up.
OR, drain whatever is in your car out and put 10w40 in it, and report back with your fuel mileage
Old Jan 4, 2014 | 01:40 PM
  #53
FRQ FLYR's Avatar
I've had the GMS1 installed since the week it was released in '09. I certainly didn't have it installed to help mpg but I did notice a slight improvement. I was averaging 28-29 running 93 octane exclusively until I parked the car a few weeks ago; mostly hwy and secondary roads. That said, whatever is ailing your car has probably been covered here. The only thing coming to mind is that if the dealership was incompetent enough to disregard whats on the filler cap they may have jacked up something else as well. Check for this-[URL="https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/line-broken-intake-tube-294387/"]
Also if you've modded the intake/filter in any way revert to stock,reset ecm and try again.
Old Jan 4, 2014 | 01:51 PM
  #54
qwank's Avatar
GM dealers still have conventional oil for everything older than a 2011, unless it came with Mobil one.
Old Jan 4, 2014 | 02:10 PM
  #55
conerboner's Avatar
did you try resetting the average fuel economy on the dic?
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Trav3480
Oct 1, 2015 08:17 PM
Stuff
Oct 1, 2015 05:47 PM
