New Track Numbers for ZZP Turbo Swap
With our local track closed for the year, we headed out to Milan Dragway for their last weekend. They were running the "No ET Nationals" which is set up for grudge races, side bets, etc... They don't run the ET boards, just the win light, and you only get your half of the timeslips. Last week, I had a lot of trouble with the throttle sitting at 50% for a couple seconds after each shift. The best time that day was 11.76 at 123. This week the ECM issues were solved and the car was running well. For the first pass, I launched decent(1.72 sixty), and hit 1-2 pretty good. I had my best 330' time by a significant margin, but miseed 3rd gear. I still managed a PB by almost a tenth with an 11.67 at 122. This pass was run with 17psi in 1st gear and switching to 23psi half way through 2nd. For the second pass, I launched about the same(1.71 sixty), but shifted 1-2 too soon and bogged a bit. I lost a full tenth from the 60-330 interval compared to the first run. At least I hit the 2-3 this time, and finished with another PB of 11.4381 @ 126.68. This pass was run with 17psi in 1st gear and switching to 23.5psi in 2nd. For the 3rd pass, they had just finished prepping the track and it was hooking hard! If I had any idea how sticky it really was, I would have launched at a higher RPM or slipped the clutch off the line. With 5psi and 6500 RPM, I let the clutch out and the car jumped about 3 feet and the grippy track completely stopped the tires. The engine bogged bad and then took off. I hit the gears great, but ran out the pass on low boost for a mid 12 with a 2.27 sixty foot. After this pass, we ran into some issues with another car and needed to rob some parts, so I didn't make any more passes. Therefore, final numbers for the season are:
531whp sae at 27psi
11.4381 at 126.68 at 17/23.5psi
Don't mind the timeslip dates. These passes were run 11-7-09.
edit- adding vids
11.67- http://www.youtube.com/user/Stattama.../2/fScOK9WS5mo
11.43- http://www.youtube.com/user/Stattama.../1/Y3PXKyj608c
531whp sae at 27psi
edit- adding vids
ZZP LNF turbo kit with Borg Warner S256 extended tip turbo from Bullseye Power
External wastegate dump tube
ZZP upper charge tube
ZZP race intercooler
ZZP ported head with 78 lb valvesprings
ZZP fuel pressure modifier @ 2750psi
ZZP 3" stainless catback
ZZP stage 4 clutch
Success!! You guys need to get a kit out by next spring to compete with synapse so that I have to decide which kit to buy! Although I'm not looking for nearly the power you guys are making...probably about 130 less at the wheels
