Is this a newer Hahn intake?
Old Nov 9, 2009 | 12:31 AM
Gimpster's Avatar
Click this link: http://www.ecimulti.org/gallery2/mai...serialNumber=1
IS that the newer style breather connection or something older?
I'm asking because its way too short, and the plastic collar inside the PCV check valve keeps pulling out. Sent an email over to Hahn, but guessing I'm going to have to fix this on my own. That connector screws onto the intake it appears, and the IS flanged right (breather snaps on). Its just too short... and it makes the braided hose lay on top of my ignition coil which also makes me sad.
Old Nov 9, 2009 | 07:11 AM
Iam Broke's Avatar
I can't tell from your shot whether it's the same as mine or not. I think my intake is closer to the engine than yours though (more toward the driver side). Look at my gallery pix.
I did wrap mine with high temp tape just to make sure it never leaks or pops off though. It was plenty long enough. I just had to reconfigure the loom for the MAF connector so it would reach without straining it.
Old Nov 9, 2009 | 07:12 AM
Br1anSStc's Avatar
hey. i believe i sold that to you. just fyi i was told by the member i bought it off of that this was purchased in the original group buy. it was supposed to be the better of the products Hahn offered. i never installed it though... hope you can figure something out.
Old Nov 9, 2009 | 10:59 AM
08SStc's Avatar
oh wow, that would be my old intake i think. yes, that is the original group buy one, it had no issues with fitment on the pcv line.
did you try turning the assembly slightly counter clockwise at the turbo, then rotating the tube alil more counter clockwise at the top of the curved silicone coupler? i think that would fix it.
Old Nov 9, 2009 | 11:46 AM
Gimpster's Avatar
Iam Broke: Yah I had to relocate my MAF wiring about the same as you did there.
08SStc
I've rotated and futzed around with it for about an hour... I'll try again though. Its to the point where I can't really move it anymore because of the little mounting pad it sits on (that rubber piece with the 2 threaded ends). I guess if I removed it off that it would most likely fit better.
Honestly I'm going to just re-engineer it for my needs, because I want to put a catch can on my car ASAP. I noticed a LOT of oil sitting in the bellows of my stock intake.
Old Nov 9, 2009 | 01:32 PM
glhs379's Avatar
i also had to relocate my maf wiring to make it work
Old Nov 9, 2009 | 01:39 PM
Iam Broke's Avatar
08SStc
I had some oil in the AEM when I removed it but I think that was mostly from the 30 lb overboost spikes when I was futzing around the wastegate solenoid lines.
No seals are perfect, 'specially on the 'Balt.
Old Nov 9, 2009 | 02:04 PM
Gimpster's Avatar
Well, its all just coming out of the breater.... and especially on cars running synth oil. I'd like to try and trap as many of those vapors as I can because I've seen how gummed up other GDI cars get on the intake side.
Breather is working as designed, I just wanna put a sealed can inline is all
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Sep 27, 2015 08:53 PM
