nls sucks sometimes!!!!
Old May 8, 2010 | 01:26 AM
pookie025's Avatar
Angry nls sucks sometimes!!!!
why some times when i nls it like bogs down sooo much? or like it has severe diehrea noises?
some times it works!!
Old May 8, 2010 | 02:18 AM
SSlobalt's Avatar
Your hitting the rev limiter before shifting. Our tachs are slow. You need to start shifting around 5800 on the tach.
Old May 8, 2010 | 08:21 AM
G Speed's Avatar
both tack and speedo are super slow....
especially speedo....
Old May 8, 2010 | 11:17 AM
pookie025's Avatar
nice ppl thanks
Old May 8, 2010 | 07:47 PM
T-Man's Avatar
Stop making a sandwich in-between shifts and you'll be good
Old May 8, 2010 | 07:54 PM
Dart_SI's Avatar
i take it that nls with all ur mods is ok? a lot of ppl are telling me to not use nls anymore after i get tuned and some bolt ons.
Old May 8, 2010 | 08:05 PM
chitala383's Avatar
im trifecta tuned with some bolt-ons and i nls quite often with no problem. the only time it ever bogs down on me a bit is when i 3-4 shift occasionaly. i think that's b/c im shifting slightly too early tho. other than that
Old May 8, 2010 | 08:06 PM
rckrz6's Avatar
i bog on the track sometimes nls from first to second if the wheels chirp hard enough
Old May 9, 2010 | 01:18 AM
leoaa777's Avatar
If NLS is not "working"...you are doing it wrong.
Hell I nls every single up-shift, after brakeboosting. 1-2-3-4 It makes a WORLD of difference.
Old May 9, 2010 | 05:17 AM
08inBama's Avatar
NLS is easy when you are stock, on a tuned car trying it with the 1-2 shift is pointless because you're going to have to ridiculously feather the gas in 2nd to get traction on any radial anyway, so any thing you gained by not dropping boost........is lost right there, lol
I find it much better to just do traditional shifting, which I do in every other gear as well... people can "claim" it doesn't abuse the car all they want, but I am skeptical of the long term... besides, with the K04 being so small of a turbo its not like you lose anything anyway as far as spooling
Old May 9, 2010 | 05:23 AM
leoaa777's Avatar
Put it like this. I have a 09' SS/tc with a KN drop in. That's it.
I have yet to lose to a tuned car. I raced a Trifecta tuned Solstice making 301whp and a GM stage 1 Cobalt with bolt ons. ???whp.
I beat them both...why? Proper shifting-brakeboosting. The split second it takes to to back to full boost/wot, is where I pull on them every single time and keep on pulling.
Old May 9, 2010 | 06:29 AM
08inBama's Avatar
lol
so now quick shifting makes up for 60whp....
i'll put it this way............. you put a decent drive(not even great) in a tuned Cobalt and the best driver you can find in stock TC...the stock car can no-lift shift, whatever you want to do, it's still going to get walked....
the whole "losing boost" is overrated, we have a SMALL ASS TURBO
lag is none existent pretty much anyway... brake boosting is pretty much a waste of brake pad as well... the turbo spools so damn quickly even without it
also take note, beating two shitty driven cars does not represent every tuned LNF on the road, 90% of them in any of the platforms would walk all over you... ****, I bet a Stage I HHR SS and a stock Cobalt would be an awesome race and they have a huge weight disadvantage over you
Old May 9, 2010 | 09:56 AM
peachpuff's Avatar
There is quite a bit of delay during a shift, after looking at some of my logs from the time you let off the accelerator to the time you're in full boost again(not back on the throttle) takes around 1.5 seconds during shifts. The throttle itself takes a full second to fully open, its quite annoying.
Old May 9, 2010 | 10:43 AM
06blackg85ss's Avatar
nls is fun tuned, specially when your trans explodes on the 2-3 shifts
Old May 9, 2010 | 12:56 PM
08inBama's Avatar
some of you guys need to drive OTHER turbo cars, all i'm saying
and with that being said, a stock Cobalt still isn't "pulling" on a tuned LNF because of no-lift shift
Old May 9, 2010 | 01:12 PM
pookie025's Avatar
lmao
Old May 9, 2010 | 02:56 PM
peachpuff's Avatar
I'm just pointing out a fact for lnf cars, there's considerable throttle delay during shifts and when full boost comes back on even on such a small turbo, hence the advantage of no lift to shift. As for the stock w/ nls vs tuned without, crappy driver who can't shift comes to mind.
Old May 9, 2010 | 02:57 PM
08inBama's Avatar
i'm not denying there is boost loss at the shift, that is common sense... I'm just saying that because there is basically no time for spool AFTER the shift the gains are minimum... if it were a large ass turbo, then yeah, I would agree with NLS is hands down the way to go... but no matter what GM claims, its abusive and I can promise you this, you go through a transmission using it, and see how quick GM is to replace it, lol
nope, they'll be playing the abuse card
Old May 9, 2010 | 03:15 PM
09BlueBaltSS's Avatar
Looks like your in my area, kinda. Im up for it if you want to try this theory of yours. I should have my new tires within a month. Hit me up.
The "lag" that people are describing is more the throttles slow ass reopening than any kinda of spool issue. Remember it takes almost a full second to reopen to wot.
Old May 9, 2010 | 03:17 PM
cmiller8006's Avatar
Pretty sure its because your spinning and when you hit second your actually at a lower rpm then you thought.
Old May 9, 2010 | 03:25 PM
For the 1-2 I usually roll the throttle to keep traction then quickly shift not nls, then 2-3-4 are usually nls
Old May 9, 2010 | 04:43 PM
lewis_trash's Avatar
My opinion is the following : Use NLS when you think it'll be necessary or beneficial.
Here's a short example:
I'm trifecta tunes 21psi + k&n. I raced a 2010 335i and thought I would smoke it easily from a roll so
1) firs I DIDN'T LNS : I walked him by the end of 3rd... 2-3 shift was pretty much perfect for both cars at about the same speed --> He pulled a fulll car on me just after the shift... was kinda annoyin
2) I USED LNS : I pretty much smoked him by 3-4 cars at the end of 3rd and he never got ahead of me.
SO, LNS does make a huge difference (in my opinion) when it's really necessary.
When you race a fartcan civic with steel wheels you may not use it.
Louis
Old May 9, 2010 | 04:49 PM
leoaa777's Avatar
Always down for a fun run. I'm usually on okrechobee road
on Sundays or weds.
To be honest I thought the solstice was going to destroy me but he admitted he never brakeboosted nor nls so that was the difference maker.
Old May 9, 2010 | 06:12 PM
08inBama's Avatar
no him being terrible at driving was the difference maker or a shitty ass tune... No-lift shifting is not going to make up the difference of stock vs tuned... 3rd gear in a stock TC pulls ridiculously weak... well, at least you think so after you drive the same car with just a tune
no one is going to buy what you are trying to sell...
http://www.youtube.com/watch?v=N4NTjtEJYU4
that is an excellent video showing the comparison, same driver, same day... tune not activated, tune activated... there is no driver a vs driver b there, because its the same guy, and its OBVIOUS which one is faster
Old May 9, 2010 | 08:51 PM
firemanfrank's Avatar
Originally Posted by t-man
stop making a sandwich in-between shifts and you'll be good :-d
007Buff
Jun 11, 2017 03:04 PM
patooyee
Oct 15, 2015 05:11 PM
Hugger1975
Oct 15, 2015 03:28 PM
007Buff
Sep 22, 2015 09:48 AM
The Rookie24
Sep 20, 2015 04:33 PM
