no boost very low hp
Old Aug 16, 2017 | 05:50 PM
dragonsprayer's Avatar
I think a got bad load of gas, filled up a month ago drove approximately 10 miles home it was drizzly. Noticed right way, a few blocks slight hesitancy figured it was the rain. Never seemed right on the way home. Today was first time driving again.
Driving today really bad. Zero boost above 3 rpm, only few psi, only 60hp or so. No knocking. Got some bad gas before that caused knocking, self defined to 150 hp.
should just drive out the gas?
could it be something else?
thx!
Old Aug 16, 2017 | 05:51 PM
Car is 100% stock with low miles. Thx!
Old Aug 16, 2017 | 05:56 PM
Codes?
jdbaugh1's Avatar
Is it going into "engine power reduced" mode? Are you throwing any other codes?
Old Aug 16, 2017 | 07:09 PM
i can get codes from autozones
The data is from RPD on 2010 ss. I'll update tomorrow, thx! I appreciate the fast replys.
Old Aug 17, 2017 | 03:38 PM
cobaltssdude420's Avatar
Could be a few things...
Old Aug 17, 2017 | 09:15 PM
mass air flow sensor
Much better now! $62 at AutoZone.
​​​​​​​thanks all!
Old Aug 17, 2017 | 09:24 PM
So what was it?
Old Aug 18, 2017 | 09:29 AM
umrdyldo's Avatar
Originally Posted by ECaulk
So what was it?
His post says MAF, but that to me sounds like Autozone read the code P0101 and told him to replace it.
To the OP. If your problem comes back, check for boost leaks.
Old Aug 18, 2017 | 10:32 AM
I agree it sounds like a P0101, that's why I was wondering what he replaced.
Old Sep 29, 2017 | 06:05 PM
looks like the turbo is gone
This car sits a lot. Went to drive it no power again. Backfiring. Reset the codes drives bad.
codes were maf and turbo the second time. Maf was replaced.
Any side job mechanics south Chicago, nwi Indiana?
Old Sep 29, 2017 | 06:22 PM
boost leak
When cold power is normal.
Does car throw a turbo code for a boost leak? Turbos work or not, once there is no boost the turbo is locked, frozen correct? Car has Boost then goes to zero.
Old Sep 29, 2017 | 06:24 PM
So what was it?
​​​​​​​sorry for the delay I parked it thinking it was fixed. Went to drive it same issue.
