No fuel pressure?
Old Oct 1, 2012 | 08:22 PM
paintballerr78's Avatar
No fuel pressure?
Well my car has been sitting since friday as a back story. Today i turned it on and guess what my rpd reads no fuel pressure at all when i start it. Just reads dashes no numbers or anything. Anyone know what could possibly cause this
Old Oct 1, 2012 | 08:36 PM
cubaniche's Avatar
The fuel pressure sensor on the rail went bad:
It is pretty easy to get to. Its right above the rail harness connector screwed into the rail itself. Replace it and your prob will be gone....unless its just not connected or the connector became loose LOL
Check it and see if the connections are all good. If so, replace it. When the RPD reads dashes like that, it usually means the FPS is bad. Cause even if the HPFP were bad or somehow the CAM follower roller broke, youd still read FP. Just my two cents
Old Oct 1, 2012 | 08:50 PM
so i need to remove my intake manifold to get to this piece
Old Oct 1, 2012 | 10:10 PM
cubaniche's Avatar
Not really. Its right there on the left end of the rail. I got to it with my wrench. If you dont have a wrench that size then you can snake a set of pliers in there. All you need to do is loosen it, then finish unscrewing it by hand. Its incredible how little pressure it takes to break it loose. I mean, thats how I did mine. Feel free to take the IM off if you feel that is necessary.
Old Oct 1, 2012 | 10:40 PM
I found it to the left of the intake manifold the only real clip area...I took it off and plugged it back in still doing it looks like mine is toast. Do i need to relieve the fuel pressure before i put in a new one im guessing
Old Oct 1, 2012 | 10:46 PM
peachpuff's Avatar
There could be up to almost 3000psi in the fuel rail after shutting down the car, so ya i'd relieve the pressure if i were you or wait a few hours for it to fall back down. There's also a port on the low pressure side of the fuel line, attach a pressure gauge and see if you get any pressure during cranking.
Old Oct 1, 2012 | 11:12 PM
The car runs completely fine the afr's are perfect still im thinkin the sensor just took a crap on me
Old Oct 1, 2012 | 11:32 PM
ItalianJoe1's Avatar
Sounds like it. Although, that sensor is used by the PCM to do other things with the engine, not just for the display, so if it really wasn't working i'd believe you would get a code and possibly some drivability issues.
Old Oct 2, 2012 | 09:13 AM
cubaniche's Avatar
For sure. I got a code, other than the dashes on the RPD, because the ECM is seeing that the fuel is constantly way above max PSI since the sensor is not fluctuating the voltage back to the ECM. The car runs perfect...until you try to give it some gas LOL Basically the ECM is in limp mode. Car runs like it was N/A.
Old Oct 2, 2012 | 09:16 AM
i cant drive my car hard anyway no 3rd or 4th gear so ill just have to limp it around..So what do you think could be causing this issue bad sensor or what
Also i have a check engine light to. i only need the car to staturday then it goes into storage till next april may when it will be sent to zzp
Old Oct 2, 2012 | 09:21 AM
Stamina's Avatar
Off topic, but did this happen on a stock transmission or upgraded one?
Old Oct 2, 2012 | 09:26 AM
its fully stock been on over 400hp and trq for about 2 years now with over 20+ track passes and 10+ dyno runs not to mention all the trips to mexico
Old Oct 2, 2012 | 06:27 PM
Fixed the issue...to bad my radiator broke on me now ahha
Old Oct 2, 2012 | 06:40 PM
FasterIsBetter's Avatar
Well, that sucks, man. :/ Its always something with a turbo 4 cylinder eh?
Old Oct 2, 2012 | 06:53 PM
Ya im gonna fix the radiator then store it till i get back around april then send it off to zzp for built head/tranny and a clutch
Old Oct 2, 2012 | 08:36 PM
cubaniche's Avatar
Wait...so you fixed the FPS issue? Did you replace the sensor?
Old Oct 2, 2012 | 11:14 PM
no i unplugged my connects from the computer and it came back on
Old Oct 3, 2012 | 10:33 AM
cubaniche's Avatar
Nice! Glad it turned out to be just a reset to fix. GLW the radiator thing
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
