No Lift Shift Squeal??
Hi everyone, I seem to be noticing some sort of squeal and or squeak coming from my car when I NLS. I do have the GMs1 kit but I don't know if this is the cause of the problem, as I dont remember my car making any unusual noises stock. It sounds as if the serpentine belt squeals when I perform a NLS. I was also wondering if the sound could be coming from the tranny with the added power from the stage kit. Adding more stress or force on the transmission when NLSing. Ive tried no lift shifting at different rpms from 5000 to 6000 with the same outcome. I was hoping you guys had some input or have experienced this problem before. Thanks for your help!!!
Yes I know this, i have done it up to 6000 rpm and around or at redline with the same outcome. I tried 5000rpm because I thought I might be doing it wrong or at to high of an rpm.
When I "power shift" my car does the same thing. I don't NLS because I'm a pansy. I thought it was the serpentine belt, but it kind of doesn't sound like it. Find out what this noise is, I demand it!
Could it be the BPV? Squeeking... maybe?
its not the bypass valve not even close enough to be confused with that sound. I was thinking it couldn't be the serpentine belt as i only have 7000 miles on my car, but that's exactly what it sounds like. Thanks for all the input so far guys its good to know I'm not the only one with this problem.
