No Lift Shift Squeal??
I think its the bypass valve. Mine makes a kind of bird sound sometimes. Like BWAAK !!! It did it more with the stock shifter when it wouldnt go from 1st to 2nd. It sounds like a cross between a Cluck and a Quack.
Wow! I found the corner of CSS where all the idiots hang out.
Seriously, keep NLS'ing 1-2, please. Tell me what noise it makes soon. Also, keep NLS'ing 4-5, tell me what sound you hear behind your car after a while.
For the record, if its a proper NLS, the throttle blade does not close, thus not making vacuum to open the BPV, so there goes that 'idea'. NLS'ing 1-2, that BWAAAAK noise you claim you hear is your ******* tires, duh. Any other time, its the belt. NOTHING else could squeak... use some common sense and rule out some possibilities. Metal on metal does not squeak, thus negating any idea concerning the trans. Rubber on metal squeaks, thus pointing to the belt squeaking. Plus, when its already been said 10 times that its a common occurrence, I would not guess at it being something major, thus belt slip.
/thread.
/thread.
i found them a long time ago................... https://www.cobaltss.net/
right click on any thread make an uneducated post, delete that tab
hit refresh make another uneducated post on the newest topic
/thread.
/thread.
It is the serpentine, check jbody forums, ecotecs are notorious for it. Mine did it from the factory with less than 500 miles on it, started only when using the A/C, now it does it all the time durring hard shifting. The tensioner isnt tight enough to keep it from slipping but it isnt loose enough to worry about it.
ah i got 70k on mine i NLS perfectly and mine does this once in a blue moon. i have a forge BPV so i dont think its that, my belts starting to look a bit worn. and i hardly ever NLS
