No_ss build thread
Old Jan 6, 2017 | 09:53 PM
  #326
no_ss's Avatar
Originally Posted by KMO43
nope I have a bottom
Hahn is a 2 piece hot side pipe?
Old Jan 6, 2017 | 10:03 PM
  #327
KMO43's Avatar
3pcs
Old Jan 7, 2017 | 01:26 AM
  #328
no_ss's Avatar
3pcs
weird
Old Jan 9, 2017 | 07:11 PM
  #329
no_ss's Avatar
new transmission mounts are in.
Old Jan 9, 2017 | 08:35 PM
  #330
FLASH1970's Avatar
looks nifty
Old Jan 9, 2017 | 10:10 PM
  #331
no_ss's Avatar
Originally Posted by FLASH1970
looks nifty
looks good, works good
Old Jan 10, 2017 | 12:37 AM
  #332
no_ss's Avatar
I made a signature! finally... lol.
Need to change it now though
Old Jan 10, 2017 | 06:12 PM
  #333
no_ss's Avatar
So after driving on the new mounts, I can definitely say they really help with grip A LOT. Good investment.
Old Jan 11, 2017 | 08:45 PM
  #334
63 Nova SS's Avatar
Powells would help more....
Old Jan 11, 2017 | 09:20 PM
  #335
He's broke can't afford Powell stuff
Old Jan 11, 2017 | 10:27 PM
  #336
Burn.
Old Jan 12, 2017 | 12:13 AM
  #337
no_ss's Avatar
Im not knocking powell but for running nt555 on the R I dont get very much wheel spin at all in 2nd. Honestly they do the same thing. It raise the rear of the engine up 1/4" and solid rubber mounts are nice. Cant complain what so ever.
Old Jan 12, 2017 | 07:49 AM
  #338
no_ss's Avatar
BUT
until someone shows solid proven data, same amount of rear engine rotation, same car, driver, track and actual comparison of times and powells having better times than zzp, youre all just nut swingin.
Old Jan 12, 2017 | 09:04 AM
  #339
FLASH1970's Avatar
is it the raising up that helps traction or just keeping the engine and trans planted and not twisting from the torque and wigglin' about?
Old Jan 12, 2017 | 09:06 AM
  #340
FLASH1970's Avatar
this is what broke people do...
Old Jan 12, 2017 | 09:08 AM
  #341
It's a rotation of the entire assembly (engine and trans) to align the axles better to prevent wheel hop due to axle angle. Powell is the one who worked with GM Perfomance in developing a different mount due to the Cobalt platform being initially engineered to function better with automatics.
Old Jan 12, 2017 | 09:09 AM
  #342
BUT
For awhile (maybe zzp changed their design to match Powells) zzp's mounts where just a direct replacement of the stockers with firm bushings and didn't actually rotate the engine to the position it needs to be.
Old Jan 12, 2017 | 09:29 AM
  #343
FLASH1970's Avatar
good to know. I know they have ss/sc kits but I thought seeing that they weren't listed for the tc ss cars they had fixed the issue.
Old Jan 12, 2017 | 02:40 PM
  #344
no_ss's Avatar
zzp has the spacer for the rear that does 1/4" on the gen2 spacer but now I see they have a gen3 spacer that does 3/8"
Old Jan 12, 2017 | 02:54 PM
  #345
The arbitrary spacing isn't going to line up the axles right. That's where Powell's comes in, his adjusts the engine, in the front and rear mount, to the correct angle to line the axles up.
Old Jan 12, 2017 | 03:15 PM
  #346
no_ss's Avatar
explain your reasoning because it did raise the rear of the engine and rotate the engine forward and it has made a huge difference.
Old Jan 12, 2017 | 03:25 PM
  #347
I'm not going to explain geometry to you, let along suspension geometry. I'm not saying it doesn't improve the angle, but there is a sweet spot and Powell has it. If zzp offers different spacers they aren't basing it on lining axles up.
Old Jan 12, 2017 | 06:33 PM
  #348
no_ss's Avatar
I completely understand suspension geometry. So really there is no proof that the zzp mounts are worse. Zzp has continually ran fast times at the track with their mounts.
Old Jan 12, 2017 | 06:48 PM
  #349
no_ss's Avatar
Also, the only difference between the 3/8 and 1/4 mounts is the 1/4 is same mount size as stock with a spacer, then the 3/8 is a bigger mount without a spacer.
Old Jan 12, 2017 | 07:29 PM
  #350
63 Nova SS's Avatar
I have had both, and will say I had more vibration with the ZZP mount by far. The ZZP mount was better than factory probably because it didn't allow much movement. The Powell mounts I have now though are better. With the same tire arraignment I could get wheel hop using the ZZP setup, have little to none with powells. ZZP mounts are pretty though.
