Noise, Bpv?
Noise, Bpv?
so on my way home from work today my cel popped up and started hearing some funky sounds. kinda hard to hear it in the vid but sounds like somethings up with the bpv. car is stock except for injen sri and custom exhaust, didnt boost over 5psi in vid for obv reasons
http://youtu.be/Qu0CXxeXOeg
def sounds like something with the bpv or vacuum for it, will check it out at work tom, but anyone else have similar issue?
I'm guessing it's that because when i was getting my BYT tune last weekend there was another kid there and his ss was making that exact noise. Nick said his bpv was getting stuck. Granted he had the forge bpv, but it could be the same issue.
Wow, that is a lot. My Forge does this some, but it's a signal that it needs to be cleaned and lubed. The stock one doesn't need either of those, so it's likely torn, or you have a bad vacuum source.
Mine was doing the exact same thing and it wasn't torn or anything. Anyways, I upgraded to the forge bpv but that didn't fix it either. You get the issue right from start up on shifts and it doesn't go away until next time you drive it or a couple drives later right?
I did the vacuum tank delete and I haven't had the issue happen since. Been running solid for about 6 months now with no issue. Give that a shot.
This reminds me. I need to check my vacuum tank. I think the check valve is bad, or the tank is leaking
I may just bypass it, since I'm going to a stronger clutch, which might end up killing my ability to NLS safely anyways.
Yeah, this is exactly what happened to me a few days ago. I posted a thread about it but hardly anyone responded.
Mine started very suddenly on my drive to work (5 minute drive). Then after work, 1 minute worth of driving and it went away. Very strange. I want to to get the Forge bpv to see if that does anything. I've also had GMS1 issues and people claim the forge is very helpful in getting rid of those issues.
On another note, what on earth is a vacuum tank delete and how do you do it?
The vaccuum tank delete is pretty simple but has very mixed reviews/results.
My understanding of it (not having done it myself) is:
There is a vaccuum tank under the intake manifold that is there for the bpv. There are two vacuum lines, one that goes from the solenoid and the other to the bpv. People either remove the tank and run just one line from the solenoid to the valve or they cut the vaccuum lines and then run a single line, leaving the tank attached.
Mine started doing that but my bypass valve solenoid was the problem. I didn't do the delete when I saw this on a bulletin.
Note: Front wheel drive platforms using the 2.0 Liter RPO (LNF) incorporate a charge air bypass valve supplemental vacuum tank. The purpose of the tank is to provide an instant source of vacuum to the bypass valve via the bypass solenoid (when it is commanded open by the ECM). This results in less pressure buildup under closed throttle conditions, thereby reducing compressor noise, surge and spool time.
Some more updates. I've found it always happens on the drive following a really short drive (less than 5 minutes). From there it will surge for at least the next drive sometimes a few. But once it's gone, it never comes back until I do a short drive again. Also seems to happen less when it's cold (less than 0C).
DANRICKARD
Oct 1, 2015 12:08 AM
