Nos
Old Dec 30, 2009 | 10:33 PM
Mike08ss/tc's Avatar
Nos
I really dont have the money to turbo swap this year. I am looking into NITROUS. I know that alot of people dont agree with NOS. I am not looking to go ***** to the wall. Like 50-75 shot. So just looking for some advice. What kit would be the best one to go with.
Thanks
MIKE
Old Dec 30, 2009 | 10:54 PM
BlackMamba08's Avatar
hmmmmm i see in the near future.............. another cracked piston thread lol
Old Dec 30, 2009 | 10:55 PM
Darkfuzion's Avatar
i dont know much about nitrous in these cars but u would need a safe setup with window switch, high octaine fuel and get it tuned
Old Dec 30, 2009 | 11:18 PM
recklessnova's Avatar
dont see a problem with it just watch knock and sneek up on a tune as with any bottle fed car
Josh
Old Dec 30, 2009 | 11:24 PM
myfakeevo's Avatar
first off, nos is a brand, its not n02.
Nitrous is completely safe as long as you run more fuel. Its Nitrogen OXYGEN. more oxygen, more fuel. Thats always been the rule of thumb right?!
so. there also zex, nitrous express. each do it differently.
also, your going to want to run colder plugs. it starts cold, and the explosion makes it super hot. so you need to run colder plugs. also change them frequently.
um...you could probably get away with a 50 shot with colder plugs. however, i recommend bigger injectors to compensate.
Old Dec 30, 2009 | 11:27 PM
burnrubr88's Avatar
omg shut up dude and stop watching fast and furious
I had the NOS Sniper kit, they go on ebay for around 250 bucks for a full wet kit. Comes with everything you need and works great. Get that and start off small, then enjoy your new addiction.
Old Dec 30, 2009 | 11:29 PM
myfakeevo's Avatar
i have a zex kit that i want to get rid of. its missing the wiring for the switch/switch/and it probably has a pedal switch. but the kit goes for 500 new and i want to get rid of it for 150. plattsburgh isnt to far awy
Old Dec 30, 2009 | 11:38 PM
RYRO14's Avatar
I wouldn't do above a 50 shot at first and see how it goes.
Old Dec 30, 2009 | 11:42 PM
SSReepur's Avatar
Buy my zex kit!!!!! Its brand new never been used very cheap too
Old Dec 31, 2009 | 12:35 AM
Sorry meant to make it n02. I have a ss/tc not a LSJ. I have really did my research on the bigger injectors but as far as i know now one makes them. The zzp car with that tractor trailer tire size turbo doesnt even have bigger injectors.
I def didnt want to go with the power commander one. Everytime i mash it then i would be in the tank. It would be to hard on the car also. How high of octane would you think.
do you have the wiring harness for the window switch
Last edited by Mike08ss/tc; Dec 31, 2009 at 12:35 AM. Reason: Automerged Doublepost
Old Dec 31, 2009 | 03:43 AM
Darkfuzion's Avatar
i hear people run like 109 octane give or take with spray
Old Dec 31, 2009 | 04:03 AM
steddy2112's Avatar
You don't need higher octane gas to run a nitrous set up.
One step colder plugs and some timing retarded in a tune would do the trick...
109 octane gas....
Old Dec 31, 2009 | 04:22 AM
Snakes709's Avatar
109 octane gas....
doesnt hurt...but not required, i agree. As long as its over 91 octane its golden. I'm going to be running 94 octane with my nitrous in my 370z. If i get everything set up...hard as **** trying to find 1 step colder plugs to hit my engine.
Old Dec 31, 2009 | 05:31 AM
myfakeevo's Avatar
sorry mike, i dont know much about the tc. you should be able to easily get away with a 50 shot then if the injectors can handle it. but as snake said ... 1 step colder plugs and timing change and you should be good to go
Old Dec 31, 2009 | 12:40 PM
SSlobalt's Avatar
A nitrous system ain't cheap, either. I say save that money and put it toward a turbo upgrade later.
Old Dec 31, 2009 | 12:52 PM
reign1's Avatar
i really dont think changing the plugs would be good.
no performance gain with the ss/tc.
stock AC Delcos are usually fine from what i have seen.
and dont run 109 octane. unless thats the only thing you will run and tune for it. my buddy blew his 08 ss/tc on 109 octane and a trifecta tune at the track. blew the rockers right off. all 4 cylinders misfired.
I would rather run meth than giggle juice. but thats because i only have 91 octane. soo.
up to you though man. talk to blazin07(sp?). he knows a lot bout nitrous setups too
Old Dec 31, 2009 | 12:54 PM
damien's Avatar
This thread tempts me to buy another nitrous kit and call it done.
Old Dec 31, 2009 | 12:58 PM
Terminator2's Avatar
Thanks
MIKE
Make sure you get a tune for that nitrous or you will blow your engine like Choko did. Nitrous adds tons of extra oxygen to the mixture thus making it way leaner than commanded. This is the ONLY situation would advise running the car richer than 12.7 A/F. You need that extra fuel to keep your EGTs and knock in check. Stock or very close to stock timing and a 12.2-12.6 A/F would be best if you are going to run nitrous on this car.
Old Dec 31, 2009 | 02:07 PM
burnrubr88's Avatar
Old Dec 31, 2009 | 02:16 PM
JohnnySasakiMGS's Avatar
Its actually N2O
Old Dec 31, 2009 | 02:58 PM
myfakeevo's Avatar
Originally Posted by JohnnySasakiMGS
Its actually N2O
Old Dec 31, 2009 | 03:08 PM
Don't blow the welds on the manifold. Oh and Vin Diesel and the mad scientist will have to tear down the engine and replace the piston rings you fried.
Old Dec 31, 2009 | 03:09 PM
That is because David (not me the other David LOL) has a fail tune. Lets inject a really rich mixture of extremely high flash point gasoline and give it very little time to burn. Partly David's fault putting 109 octane in his car, but If his A/F was not so rich he likely would have not had that issue.
Old Dec 31, 2009 | 03:55 PM
I know right now that my a/f is 12.9-13.0. so it will have to be alot richer than that.
Old Dec 31, 2009 | 04:07 PM
reign1's Avatar
ehh hes doing better..........
