not boosting all the way, and feels and sounds weird. help?
Old Mar 27, 2011 | 02:19 PM
Turbalt2010's Avatar
ok guys, so the other day i was leaving a friends house and was pulling out and saw a car coming and i was allready like in the road so i eased out more and all of a sudden BOOM the whole front end of my car hit the ground, so im like what the ****, it was dark so i gave a quick look and nothing major happend that i could see, just some scraping.
i left the house went down the road and hit full boost to make sure everything was ok, and i didnt notice anything different. NOW the next day im not boosting 20 im only boosting 11-15 and it sounds weird like i may have a boost leak, im not 100 percent sure on that. and also when i get on it its really jerky. like it losing power then gaining it back again. and idk what it could be.
i only have a intake, downpipe, Forge BPV and a 20-22 psi trifecta tune.
may i have cracked the intercoller? i inspected the intercooler and i saw some rubbing on the plasitc of it and the little bar that runs on the bottom of it came loose. ill get pictures asap.
anyone have any ideas what it could be?! may it just be i need to grease my BPV? erg idk lol
thanks in advance all!
Old Mar 27, 2011 | 02:23 PM
WHITE TC's Avatar
sounds similar to when i blow a fold out in my intercooler check for boost leak u will wanna check the intercooler most likely
Old Mar 27, 2011 | 02:25 PM
im stilla n00b to all this, so how do i check for a boost leak? and also if thats the case the intercooler is junk right? time to upgrade?! lol
Old Mar 27, 2011 | 02:28 PM
Red_SS/TC's Avatar
Has to be the intercooler i think the condensor hanging off the stock ic has to do with something
Old Mar 27, 2011 | 02:31 PM
is the condesor the bar on the bottom? cuz i damn near ripped that ****** off lol
Old Mar 27, 2011 | 02:37 PM
Red_SS/TC's Avatar
Haha yeah dude thats it. Ive read somewhere that if you take that thing off and fill the holes with jb weld its better or something like that. I personally would just order a aftermarket Ic and never have to deal with the stock ic again.
Old Mar 27, 2011 | 02:39 PM
do you know where i could find that info? just so i can check it out because obviously i would have to wait for the new ic to ship and i drive over 100 miles a day. i dont wanna hurt anything. i def plan on getting an after market ic asap thou.
Old Mar 27, 2011 | 02:59 PM
also if it is in fact the ic, what ic would you guys reccomend? im not planning on doing much more then i have done now. so really i just need like the next step up from the stock junk one.
so what one? keep in mind im not made out of money lol
Old Mar 27, 2011 | 03:03 PM
Red_SS/TC's Avatar
Go with one of the new replacement ones that either Treadstone or ZZP came out with. They're not that much and is basically just an upgrade from the plastic end tanks. I really don't remember where I read that but im sure if you search a thread about a stock broken ic you'll find someone saying something about it.
Old Mar 27, 2011 | 03:04 PM
allright thanks for the help!
Old Mar 27, 2011 | 03:12 PM
if im correct the intercoolers that will fit are the TR12 and TR8 and TR8L.
im going TR8/TR8L because its a little cheaper lol but does anyone know the different between the TR8 and TR8L? they are the same price.
and also i still have stock charge piping, this will work right?
TR8 Intercooler- TREADSTONE PERFORMANCE
EDIT the TR8L is for a lower boost with higher flow, so id assume the TR8 is what i want...
Old Mar 27, 2011 | 03:48 PM
Old Mar 27, 2011 | 08:19 PM
bump, anyone else think its deff the intercooler?
Old Mar 27, 2011 | 08:29 PM
jarhead's Avatar
Yes as the other guy said air flows through the metal condensation tray so if it's hanging you have a boost leak from there. If you drive it you will eventually get a cel because it is a air leak after maf sensor before intake manifold. You may or may not have a crack in the plastic end tank also does not take much of a hit. As the other guy said you may be able to I think guys use jb weld on the condensation tray hole to patch them until you get you're new intercooler if you have no other leaks/cracks from the end tanks.
Old Mar 27, 2011 | 08:41 PM
Originally Posted by jarhead
Yes as the other guy said air flows through the metal condensation tray so if it's hanging you have a boost leak from there. If you drive it you will eventually get a cel because it is a air leak after maf sensor before intake. You may or may not have a crack in the plastic end tank also does not take much of a hit. As the other guy said you may be able to I think guys use jb weld on the two condensation tray holes to patch them if you have no other leak from the end tanks.
allright, well new intercooler here i come lol. thanks for the input.
Old Mar 27, 2011 | 08:54 PM
YelloEye's Avatar
You can check if you have a boost leak by spraying your intercooler piping and intercooler with carb cleaner, if the RPMs mysteriously go up when you spray a particular spot there's a leak there.
I'm voting you busted the condensation tray. You want the TR8, I believe it actually sits higher than the stock intercooler as well. Treadstone is running a sale I think on the kit.
Old Mar 27, 2011 | 08:57 PM
but there isnt like a crack, just the one side of the tray came off of the bottom of the intercooler soooo idk what id spray lol. and yes i signed my self up for the TR8.
Old Mar 28, 2011 | 01:19 PM
So my car threw a code today. P0101. Something about the mass air flow sensor efficiency. Could this still be the intercooler? I really don't want to replace it and that's not the problem. If anyone could chime in that would be awesome!
Old Mar 28, 2011 | 03:51 PM
bump need help lol
Old Mar 28, 2011 | 04:09 PM
CudaJoe's Avatar
The code you threw is definately a boost leak. The condensation bar you said was "Fuked up!" is the culprit.
Take the condensation bar off and fill with JB weld for a quick fix till you get a new IC. Treadstone has a groupbuy going on right now for a TR8 Intercooler with all the necessary clamps and hardware. I made a DIY install thread you could follow if you want to install it yourself.
The TR8 groupbuy is $250. Not a bad deal for a better than stock IC. TR8 is a 600 cubic inch intercooler. The stock IC is 542.5 cubic inches. TR8 will match up to stock charge piping. I did a IAT temp comparison between stock IC and TR8 and saw nothing negative about the TR8. Of course I didnt floor it and do multiple pulls to really try and heat soak either.... but it is very functional and Im pretty happy with it.
ZZP is also making a stock replacement IC. Its under developement now. If you wanna get in on the treadstone group buy, act fast, the link to purchasing is up.
Old Mar 28, 2011 | 07:37 PM
just ordered my treadstone IC, thank you for the info and the awesome group buy just as i fucked my **** up lmao.
also when i take off the condenser tray what hole do i fill? not the slots in the bottom of the ic right? or is there holes on the left side of it when i pull out that screw that i need to fill?
Old Mar 29, 2011 | 05:19 AM
cudajoe if you could pm me exactly what to do with taking off the condenser bar and filling he holes with jb weld that would be awesome. im gunna be at school and wont be able to get on here and if you pm me wit will go to my email and ill be able to look at it on my phone. thanks!
Old Mar 29, 2011 | 09:08 AM
CudaJoe's Avatar
Turbalt2010
I tried a search and didnt come up with anything. I think its pretty straight forward. You fill the mount holes with JB weld. I think the bar is mounted on one side with a bolt while its held in place with a clip on the other side? Thats a guess. Search TRE TR8 DIY install to see my install thread. YOu can use that to take the bumper off if necessary to see if your endtanks are cracked.
https://www.cobaltss.net/forums/2-0l...cooler-245952/
Found this thread where someone had the same issue.
If you type intercooler into the Search this forum menu on the top right, you will see a whole slew of issues the stock IC has had. There's alot of people that have knocked off the condensation bar (water trap bar) and also blew the stock IC under stock and tuned boost levels.
Old Mar 29, 2011 | 09:42 AM
Ok well the one side doesnr have any hole in it so i assume the left side that is still aracjed it the side with the hole in ot that i ned to patch. I uope thats it or else im prolly fucked lol
Old Mar 29, 2011 | 09:47 AM
CudaJoe's Avatar
yeah that sounds about right. Patch the one visible mount hole. As long as there isnt any other cracks then you should be ok temporarily.
