o2 housing
Old May 26, 2011 | 04:48 PM
paintballerr78's Avatar
o2 housing
Does anyone know how many bolts hold the o2 housing to the Turbo
Old May 28, 2011 | 01:30 AM
gone_in_10_sec's Avatar
the whole O2 unit is one bolt [ie spark plug], if your changing it, unplug your battery first then unplug the O2 unit plug [right side of the valve cover], then unbolt it..
when installing a new O2 sensor don't plug it in, wait until the sensor is fully bolted in, then plug it in..
Old May 28, 2011 | 01:35 AM
HB_SS/TC's Avatar
any pics of the sensor location? I may have to change the o2 sensor this weekend
Old May 28, 2011 | 08:19 AM
its on the down pipe, here is a pics of it..
Old May 28, 2011 | 12:23 PM
thats not what i was talkin about i was talkin about the 02 housing that bolts up to the turbo that the downpipe connects to
Old May 30, 2011 | 10:51 AM
IsItFast?'s Avatar
Thats the rear O2 sensor.. definitely not what he was asking about.
BTW changing the front O2 is a bitch and a half when you have big hands/arms. I had to get at it from underneath and had to remove the rear mount to get to it.
OP - are you just changing the o2 sensor or trying to remove the housing from the turbo for some reason?
Old May 30, 2011 | 07:40 PM
im doing a turbo swap and i was removing the whole setup and the turbo wouldnt drop down without the o2 housing off but we got it off finally just had to drop the support beam that held up the turbo and turn it and unbolt its easier than it sounds
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Slick_Nick
Sep 28, 2015 09:15 PM
