Odd issue with lnf.... HELP!!!!
Old Sep 15, 2009 | 10:32 AM
Bades's Avatar
Hey guys I just bought my gf a ss tc.... well I have a problem I think her boost fluid is really low... the gauge reads -20.... is this bad????
should i take it into the dealer???
can I fix this issue???
thnx guys for all the help...
Old Sep 15, 2009 | 10:34 AM
madmark's Avatar
wtf lmao.....all the time even under boost
fredds-turbaltSS's Avatar
is this a joke??
Old Sep 15, 2009 | 10:36 AM
northvibe's Avatar
is honda owner...of course its a joke
Old Sep 15, 2009 | 10:38 AM
kissmySS08's Avatar
i hope you're kidding....
if not, at idle the boost gauge will read *20* vacuum pressure... i.e. NO BOOST
if it still reads vacuum under acceleration you've got a problem. My guess wiring and/or MAJOR boost/vacuum leak lol
Old Sep 15, 2009 | 10:39 AM
madmark's Avatar
walmart has boost fluid on sale..... 3 dollars for a gallon
Old Sep 15, 2009 | 10:43 AM
Stamina's Avatar
You're obviously out of boost then and need to get more. It goes faster when the gauge reads 15+.
Old Sep 15, 2009 | 10:52 AM
umrdyldo's Avatar
Yeah just take the boost fluid, pull off the hotside piping and pour it directly into the intercooler. You will have 30 psi easily.
Old Sep 15, 2009 | 10:55 AM
Bades's Avatar
ok guys thanx... i want to be able top beat 911 turbos wit just sum more boost fluid and a tune.... is it safe to just pour the fluid in the pipe??? how much do i put in???
Old Sep 15, 2009 | 10:58 AM
BYT*SS*TURBO's Avatar
Somebody is bored...
Old Sep 15, 2009 | 10:59 AM
northvibe's Avatar
walmart is having a sale on 3 quarts for $29.97.
Well if you put some in your intake you get better pre boost, some in the charge pipe to get better driving boost and if you just squirt a tad in the exhaust manifold you'll get hella better boost on the top end. Ebay may have some but its usually a chinese knock off.
Old Sep 15, 2009 | 11:05 AM
Bades's Avatar
ok thnx guys ima head to wally world and pick up a few gallons of the boost fluid... any special brand???
(yes im hella bored..... and sum guys seriosuly asked us that today at work.... people are soooo fuc*ing dumb!!!)
drew1991sf's Avatar
when she gets the tune tell her to go race a 997 911 turbo or zr1 or gt-r she'll smoke all of them. tuned lnfs are prolly the fastest things in the world.
Old Sep 15, 2009 | 11:12 AM
Bades's Avatar
soooo true.... the lnf is a maonster.. i mean it destroys my s13 by like 6 cars.. and its only 2 days old... lol
Old Sep 15, 2009 | 11:19 AM
tREBs's Avatar
While your at it you might as well top up your blinker fluid as well!
freaking stuff runs out so fast!
Old Sep 15, 2009 | 11:24 AM
Projekt's Avatar
syntetic blinker fluid man..dont use conventional
Old Sep 15, 2009 | 11:28 AM
Bades's Avatar
oyea.. i only use synthetic blinker fluid... does the boost fluid *** in synthetic???
Old Sep 15, 2009 | 11:31 AM
Projekt's Avatar
lol noob.
boost fluid is just a 50/50 mixture with meth and transmission fluid. its cheaper if you make it yourself..i use windshield washer fluid and transmission fluid.
you know that high pitch whine you get when you go in reverse..thats fine..thats just your muffler bearing working backwards
Old Sep 15, 2009 | 11:39 AM
wantedSS/TC's Avatar
I urinate in my boost fluid container. Works wonders.
Old Sep 15, 2009 | 11:43 AM
Bades's Avatar
odamn man... urine??? really?? it must not be as good as the tranny fluid and washer fluid combo... u only ran a 13.8?? my gf ran a 8.91@ 189mph stock....
side note: I got my boost fluid and poured it in the intake..... the fmic piping... and the exhaust manifold... now it wont start and just cranks over makin a loud knockin noise... wat did i do wrong??? should i take it to the dealer now???
Old Sep 15, 2009 | 11:46 AM
tREBs's Avatar
No you need to flush the system! you probably put in too much fluid!
try getting a large bowl of water, and put your intake in the water and crank the car again, the intake should suck up the water and cleanse your engine!
Hope this works
Old Sep 15, 2009 | 11:48 AM
yeah, only 13.8. Funny you mention that, I was actually pushing my car down then 1/4 mile at that time posted. What gives??
Now that I'm tuned though, with no interior and charge pipes that weigh 2 grams, I should be quicker. Keeping by fingers crossed.
Last edited by wantedSS/TC; Sep 15, 2009 at 11:48 AM. Reason: Automerged Doublepost
Old Sep 15, 2009 | 11:51 AM
Bades's Avatar
Just messin man lol!!!!!
Ok treb ill try the bowl of water... Can i use a bucket????
Old Sep 15, 2009 | 12:45 PM
CudaJoe's Avatar
I think the best way to flush out the cars engine (and the easiest way) is to drive you car into your neighbors pool while its running. THe car will shut off after a moment being submerged, thats ok, you just need to stay in the car and keep turning the starter over. this is how you get lots of chlorinated water into the turbo and the charge piping and the intercooler to flush out the old boost fluids.
Its difficult to get the car back out of the pool, but still not as difficult as trying to pull the motor apart to change the boost fluids manually. on a side note, you car will be super clean inside and out!
Old Sep 15, 2009 | 01:28 PM
I was LITERALLY hand and foot, pushing my car down. lol
