Offical Exhaust Thread
What do you guys think about Running the car with out a muffler with 3' piping and 3' DP?!
Anyone done this yet?
I like my sound frommy muffler delete and i want to keep that but make it deeper if possible!
Any comments? Suggestions?
Edit: 3" tubing will have a deeper sound then the stock 2.5" tubing but I you are going catless you should run a muffler unless you like it really loud all the time. I like mine loud at WOT and quiet while I am cruising.
what he said. lol
Im prolly going to go with a DB muffler from corsa instead of the one that comes with the exhaust system. the bigger muffler will help woth the airflow. so 3 in cat back stainless steel piping with a db muffler. prolly a 3 in clear image DP with cat.
Gunna sound good!
Gunna sound good!
what he said. lol
Gunna sound good!
Gunna sound good!
Not to get off subject to much but has anyone found any other dual outlet set ups other than the Loundmouth, i was wanting to go with hahn but something has me hooked on the look of the duals.
I see they do make universal mufflers now, but only 2.25" and 2.5" no 3" size mufflers. If you decide to go with a 3" catback you should get a true 3" muffler that way you are not creating a bottle neck in the system.
well even if it is bottle necked, it is for a small portion. especially with a 3 in DP it shouldnt be toooooo bad. but ill see..
as far as a dual exhaust man, you might have to go custom for it. other than the SLP but it is soooo loud.
http://www.youtube.com/watch?v=pWZon9FqTW0
LNF 3 inch turboback, no muffler, no resonator. only a high flow cat
has anyone "unbolted" the exhuast on the ss/sc's yet i know the celica and rsx-s guys do it and it sounds really good. i made a thread asking this question a while ago but noone had an answer.
might want to post in the LSJ section or hell even the lounge.
LNF=turbo.
totally diff man
I've beening running SLP loudmouth 3in muffler since Oct. Currently on my stock dp and stock piping. My custom piping is on order i am waiting it will be all 3in no res (stainless 304). DP will either be cat or catless cant make my mind up.
PART # 31066
I did some researching on this muffler I tried for awhile to get SLP to make a setup for the SS/TC but they stated they have no plans on doing so at the time. So i decided to look around and this was in the Camaro section it does not have the resonator inside its loud and sounds sweet!! I maybe the only one on here that has a SLP setup for the SS/TC
I also have the 31067 muffler that has the resonator inside will be seeing how it sound once i get the whole exhaust done. Here is a vid what the 31067 with chambers sounds Here is a vid that compares both
http://www.youtube.com/watch?v=Z0nr7...ext=1&index=11
PART # 31066I did some researching on this muffler I tried for awhile to get SLP to make a setup for the SS/TC but they stated they have no plans on doing so at the time. So i decided to look around and this was in the Camaro section it does not have the resonator inside its loud and sounds sweet!! I maybe the only one on here that has a SLP setup for the SS/TC
Hey "reign 1" spend some cash and get real HIDs, not those dumb fake colored bulbs that really don't put out anyplace near 40000k ........
You do know that running a 50w ballist with your 5k hids will make them put out less light then OEM 4300k's? just do the 5k with the 35w balist... it's the only way to get the most true 5k light output...... or do 6k with the 50w ballist which will give you 5k light output......
DP's and exhaust do not give these cars much hp until your over 320 whp
Last edited by SportredSS; Feb 12, 2009 at 09:42 PM. Reason: Automerged Doublepost
So i was reading else where on here and they said something about the warranty becoming void if you do more than a catback, meaning a DP. So maybe stupid question but does this include if the DP still has a cat in it? Will it still void it?
yes my car came that way... sounded like ****, and birds dropped from the sky every time I drove over 50mph.
[QUOTE=SportredSS;3459699]Hey "reign 1" spend some cash and get real HIDs, not those dumb fake colored bulbs that really don't put out anyplace near 40000k ........
You are very wrong about the light output here. A 50W puts out 30% more light than a 35W period. A typical 35W OEM HID is around 3200 Lumens mine are around 4000 Lumens. Dont believe me, ask anybody who knows about HID they will confirm what I said. Operatic has picture showing how much brighter a 50W is than a 35W same bulb and everything.
DP is worth around 15 whp on these cars with just a tune. Catback is not as necessary as it flows better than the stock DP.
