OFFICIAL Treadstone Stage 4 Install & Review
What are u doing for the tranny? someone was saying zzp tranny is good for 400whp and we easily have more than that
gonna pray alot lol my intentions are to find an LSJ tranny, have it rebuilt, and the gears and stuff cryo'd. Bulletproof? No. Stronger than my OEM LNF tranny? Yes.
As stated above, my internals were stock till about July (about a year later). On stock internals and head i was spinning to 7000 i think. I have since upgraded the valve springs and retainers as well as rods and pistons and i am now spinning to 7500. As for slowing the boost hitting...its a bigger turbo than stock so it has lag...therefore it doesn't hit like stock turbo. But you can adjust how the boost ramps in with your tune.
And when you say PPC tuner..do you mean the Hahn tuner? If so, i say yes you definitely need to upgrade to either an HP Tune (prefered by me) or a Trifecta tune.
This
or at least, less likely to break
The ZZP is a F35 trans with the 4.45 gearset (from a Saab I believe) and some other internal work done. I think bearing clearances tightened and such. It should be detailed on their website.
- F35 Transmission #
Heeeelllp!!
I need help, at first i wanted to run a bov on my cobalt then after a lot of thinking ive decided to just go with the bpv. bad news is i done ordered a zzp charge pipe with the flange, so im wondering is there a block of plate for it or do i need to order a whole new charge pipe(which i hope i dont have to). plz help!! thanks!
Sent from my Samsung Galaxy S4 using CobaltSS
