Oil Advice
Hello gang! First, thank you to everyone in this site that has helped me with reference, I have been working on my car for 19 months after I melted one piston, apparently 28psi on a stock turbo is a big no no
I will be turning on my car tomorrow and my mechanic suggested me to use Valvoline racing vr1 20-50.
Here is a list of mods
Block:
Neutral Balance Shaft
LHU pistons (slightly more compression)
Head:
Race spring/retainers zzp
Head Port/port matching for manifold
Turbo: Precision 57/57 .63ar oil cooled only
Tranny:
Final ratio 4.45
obx race lsd
Cooling:
Modern performance intercooler
Mishimoto race radiator
The car will be tuned for daily/autocross 415whp @ 18 to 20 psi, I feel uneasy chaging the type of oil used in the car. Is the oil mentioned a good move?
Block:
Head:
Tranny:
Final ratio 4.45
obx race lsd
Cooling:
20-50 oil is thick and there is no way I would run that. I would also advise you to make sure it's getting tuned by someone who knows these engines well and not by the guy who caused your piston to burn. You can run 28 psi on a stock turbo without burning the pistons. It's not going to gain you much of anything but it's doable.
First things first, your mechanic is a retard for saying to use 20/50 on a ecotec. 5/30 is perfect for everything it was designed for. After I built mine, and had it built with a little looser tolerances I ran 10/30.
Stick to 24 psi and under on stock turbo, safer and u won't gain anything hardly over that . Slap ur mech in the head for suggesting that oil. Use only full synthetic 5w30 4718 certified oil. Mobile 1 or another good brand. I use penzoil platinum and she loves it. Ask me how I know
Ie: 5w-30 oil will flow like a 5 weight oil at 0 deg C, but will thicken to a 30 weight oil at 100 deg C.
Welcome to the world of multi-viscosity oils.
Just so you know, you are still running a 30 weight oil. The beginning number has nothing to do with the oils final viscosity rate; it's used to determine the oils flow point at 0 deg C.
So what, the looser tolerances magically disappear once everything is warm and has expanded? If you were to run a looser tolerance, you'd jump up at least a grade on oil, to say 5-40 or even a 50 weight. I sell oil to guys that run anywhere from 500-1000hp pulling engines that run straight 50 weight oil, one runs off methanol. But hey, I guess you know everything and I'm the smart ass on here. Smh.....
Yeah actually I do builds motors, quite a few of them from stroker pulling motors to yzf 450r motors. Oh, and my 482awhp 4G63 boosting one of the first PTE 5756 turbos that came out in 2007 running Megasquirt V3.
I also have an associate's degree in metallurgy.
I guess you run whatever oil you want, but don't steer the OP in the wrong direction. Simply running a 10w-30 in place of a 5w oil when it's 30 or above out does absolutely nothing.
Done arguing with you here. Good day.
Big deal you have a associates degree in metallurgy, that means you literally are starting to scratch the surface of information. I.E. enough knowledge to be dangerous because you think you know it all but honestly have no clue.
Also glad you're wiping your dick out with the "big power" numbers on the first PTE build
Wow you guys are being real dicks here lol..
Its okay if someone has a difference of opinion, thats why were all here. To see things from different viewpoints.
Carry on
Carry on
camaromanss1992
Oct 1, 2015 10:51 PM
