Is this the oil bolt?!
Old Jul 4, 2011 | 08:41 PM
Iturbo's Avatar
Unhappy Is this the oil bolt?!
I was attempting to change my oil today since I moved and no longer have free oil changes through that dealership. I looked at the "how to" thread but I couldnt find that bolt I figured that was on the older models. Is this the bolt the oil is going to come out of? (taken from phone)
Because if so this bolt is NOT coming off...dead locked like a bitch
Old Jul 4, 2011 | 08:42 PM
AndrewSS/TC's Avatar
Yeah. That's the drain plug put some muscle in it while it's still warm should come out.
Old Jul 4, 2011 | 08:44 PM
devon9832's Avatar
just don't over tighten it...
Iturbo's Avatar
I knew it...i think the the dealership wants money...i have no power tools atm...just a short ass socket kit...******* pissed cause i need this change
Old Jul 4, 2011 | 08:46 PM
heathkidder's Avatar
if you cant get it dont be a tight ass go get it done. ull regret it when u start letting it go over when it gets up in the milage
It shouldn't be THAT tight though, th dealership prolly overtightened it. You should be able to do an oil change with basic hand tools. No power tools needed.
Old Jul 4, 2011 | 08:49 PM
Iturbo's Avatar
Yeah did all my own on the srt4...
ps not being a tight ass...already up in the mileage...JUST got screwed by chevy because my car got the "key stuck in ignition" issue and they tried ******* me over
now all I need is to pay for an oil change plus labor when I can do this myself...well...thought so lmao
devon9832's Avatar
Yea, the hardest part is the filter if your s/c'd. Other than that, you should be good.
Old Jul 4, 2011 | 08:50 PM
Iturbo's Avatar
t/c'd
Old Jul 4, 2011 | 08:51 PM
My car had the key problem too. I rigged it.lol
BumbleBee's Avatar
mine was like that too, just use a mallet to hit the socket handle. worked like a charm
it's only suppose to be 18 ft lbs when you put it back in.
Old Jul 4, 2011 | 08:52 PM
devon9832's Avatar
Originally Posted by Iturbo
t/c'd
stupid me... reading your s/n would have told me that... lol
Old Jul 4, 2011 | 09:01 PM
09CobaltSS1's Avatar
2 words for you my friend which is a very simple and old mechanic's trick..
double-wrench!
meaning.. take your 15mm box end wrench or ratchet handle (depending on which you're using of course)and add another wrench on the end to add more leverage by esentially lengthening your handle. You can even just take a small length of pipe and slide it over the end of your socket wrench handle and get the same effect.
Old Jul 4, 2011 | 09:02 PM
Karlen89's Avatar
Breaker bar and a six pack of ******* man.
Old Jul 4, 2011 | 10:02 PM
themacguy's Avatar
I think it's 28 ft lbs.
Old Jul 4, 2011 | 10:21 PM
BumbleBee's Avatar
25nm, 18ftlbs
18 for the oil filter cap too
Old Jul 5, 2011 | 02:16 PM
silverbullet08's Avatar
Not to be a dick but are you sure your losening it? common mistake for people that dont usually work on cars or anything. You should be turning it counter clockwise when your looking at the head of the bolt.
Old Jul 5, 2011 | 02:21 PM
superbrowndude's Avatar
A bar from a floor jack would fit over the ratchet handle dude,or combine another wrench to the end of your wrench...but if your having these kind of difficulties already,maybe pay someone else to change your oil .
Old Jul 5, 2011 | 02:24 PM
Staged07SS's Avatar
Administrator
Administrator
18 ft-lbs
Old Jul 5, 2011 | 07:42 PM
SSRich's Avatar
don't forget go left with it righty tighty lefty lousey
Old Jul 5, 2011 | 08:09 PM
WV-CobaltSS's Avatar
Haha gosh I love reading everything everyone posted. But I'm gonna say what the others say if youre having to much trouble just getting it off. Or even asking where it's at. I would just go get it done. N just add a little elbow grease, and you said it's a TC right. So you have to use good oil not the regular. Which sucks bc I hate paying that big price so I do mine own
Old Jul 6, 2011 | 07:26 AM
themacguy's Avatar
25nm, 18ftlbs
I stand corrected.
Old Jul 6, 2011 | 07:40 AM
05Slowline's Avatar
can try hitting it with a torch for a min or two to heat it up a lil and persuade it lol they probably air socketed back on ****** places and their air tools need to learn how to use them
Old Jul 6, 2011 | 08:15 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Pull out the tampon and try again, sissy boy.
Old Jul 6, 2011 | 08:21 AM
SuperchargedSS's Avatar
There is a washer/seal on that oil bolt. It will need to be replaced if it's really aped on like you say.
Don't forget to replace the gasket on the filter too and prime it a bit.
Just use a double wrench or a breaker bar like above. If that doesn't do it drop the oil pan? Haha.
