Oil cooler delete?
Oil cooler delete?
Currently looking into swapping an LNF into my project car. Only problem is the trans I'm using of this car supposedly cannot run on 2.0 ecotecs because of the oil cooler. Are there any kits to remove the oil cooler?? The car has been swapped before by many people with 2.4 and 2.2 ecotecs engines. I am trying to create the first LNF swap and can get all the parts to do the swap. Only thing stopping me is the oil cooler hitting the bell housing.
It just might be a good ol mx5 😏
HGT I like that solution you have there, seems like that could work. I was looking for a delete kit or even relocation.
I can have the adapter made for the flywheel, like I said everything is good to go except for the oil cooler and ECU as I just discovered they are not available to tune as stand-alone ECU and requires the BCM to function properly. I read trifecta could do it but apparently they stopped offering that service. Atleast that's what one of the reps there told me.
Still researching as this is still an idea and it will for sure receive an ecotec transplant just deciding whether to go lnf or not. The oil cooler is one of the things holding me back.
AFAIK yes you need the BCM to run the e69 on the LNF.
You must share the adapter design. I am much curious.
I (very briefly) considered this. I decided the extra cost and complexity wasn't worth it. The only that it was happening was to get a wrecked Solstice GXP basically gifted and that wasn't happening. Otherwise way too expensive when I could boost the LE5 if I lacked power.
I (very briefly) considered this. I decided the extra cost and complexity wasn't worth it. The only was that it was happening was to get a wrecked Solstice GXP basically gifted and that wasn't happening. Otherwise way too expensive when I could boost the LE5 if I lacked power.
The adapter design is not my own but from a company that makes the swap kits for the mx5. They also make one for 2.0 engines upon request.
I just read that MTM would make a flywheel for you. I was curious how they would make an adapter for the 6-bolt Miata flywheel to the 8-bolt 2.0 crank, but that explains it. If you are interested, i would have that priced before committing.
Another option for the ECM is through AlphaFab but that is extremely pricey. May as well just buy the BCM.
I read an old thread from 2014 where trifecta made what they called a layered tune, or something like that. They made a trifecta file to upload and then you could tune certain tables with hptuners. That's how stand-alone was possible. After couple hours researching I could not find a lead to use hptuners for stand-alone on the e69 without a BCM. I'm thinking just doing a 2.4 and a ko4 turbo for now. A friend has a 6 speed Miata trans I might pick up and start the swap. I believe it be around 2k-2.5k I'd spend on the swap but one always spends more than planned for a job like this lol
I'm guessing you already have the LNF sitting in your shop, or a lead on a dirt cheap one, if you're willing to go through the headache of dealing with that pcm.
I'll always say LSJ FTW, but in this case it's even more true. Standalone buggy harnesses are cheap and easy.
05BlackSS
Jul 9, 2010 02:10 PM
StevesBlack06
Nov 10, 2009 12:13 AM
2K5SS/SC?
Apr 19, 2006 12:07 PM
