View Poll Results: Which one first?
Ic piping
22
50.00%
Trifecta Tune
22
50.00%
Voters: 44. You may not vote on this poll
Which One First???
Old Mar 18, 2009 | 04:11 PM
SSturb's Avatar
Which One First???
OK, so i cant decide on what to get first. A tune or IC piping? I really want to get the tune first but im worried if i get the tune first my stock IC piping will break. So what im asking is, should i get the IC, first or Tune?
Old Mar 18, 2009 | 04:13 PM
widowedeight's Avatar
i have a tune and everything is fine here..... if isn't a mild tune either...make a poll?
Old Mar 18, 2009 | 04:17 PM
Buddhaphish's Avatar
I would look into swapping your ECU first ... Its not as expensive as you might think . Then you can swap your stock at your own leisure ...
Old Mar 18, 2009 | 04:18 PM
MP Cobalt's Avatar
Get the IC Piping first then get the tune.
Old Mar 18, 2009 | 04:21 PM
recklessactn's Avatar
IC piping, set yourself up for before the tune rather than playing catch up, plus there are known issues with the stock IC piping as well
Old Mar 18, 2009 | 04:22 PM
sport08's Avatar
x100000
Old Mar 18, 2009 | 04:23 PM
reign1's Avatar
MOTHER ******* NEW MEMBERS USE THE SEARCH BUTTON!
sorry....
/Rant
Old Mar 18, 2009 | 04:29 PM
det_lions87's Avatar
IC Piping first.
Old Mar 18, 2009 | 05:49 PM
Stamina's Avatar
IC piping first. Not only would you no longer be running the risk of issues with the plastic, but you could take full advantage of your new configuration so you could get most out of your tune. I don't see any advantage of doing it the other way unless you just can't wait for a tune.
If you did the tune and then the IC piping, you'd have to probably end up getting re-tuned eventually anyway to "lock in" the changes the made with the IC piping if you wanted to get the most out of it.
Edit: Oops, didn't pay attention to the kind of tune. If it's canned, then the performance part doesn't matter as much. I might still go with the IC piping though because of its known issue though.
Old Mar 18, 2009 | 07:39 PM
Mazdaboi318's Avatar
Its split because you should get both lol...
Old Mar 18, 2009 | 09:11 PM
Mike09SS's Avatar
No issues yet with my IC piping...had a tune for over 1k miles....stock tubing still seems strong...not loose or anything. then again it is a common issue...
Old Mar 23, 2009 | 06:07 PM
SSturb's Avatar
just ordered my IC piping. i just got the hot side. and a Bigger spring. cant wait til it gets here.
Next order of business..... Install and TUNE~~!!!!!!
