only getting 6 lbs of boost
Old Feb 18, 2011 | 10:23 PM
ORLANDO09SSCOBALT's Avatar
Unhappy only getting 6 lbs of boost
I installed bad-mad catless down pipe first and everything was fine. This week I installed Hahn cold air. Engine light is on and I am only getting 6 lbs--HELP! Did not go in to find out what cel code it is.
09 tc/ss 48,000 miles
Old Feb 18, 2011 | 10:33 PM
Old Feb 18, 2011 | 10:35 PM
08ssedan's Avatar
Im guessing the intake fucked your **** and you need a tune.
Old Feb 18, 2011 | 10:37 PM
AndrewSS/TC's Avatar
6psi sounds like limp mode
Old Feb 18, 2011 | 11:28 PM
TommyP's Avatar
AWD > FWD
Have you considered putting the stock intake back on to see if it's causing the problem?
Old Feb 18, 2011 | 11:31 PM
YelloEye's Avatar
Maybe you should find out what code that is......ya know...useful information is typically gleaned when you know wtf the computer is trying to tell you....
Old Feb 19, 2011 | 12:33 AM
D-mac's Avatar
Did you mess up the connector on the intake housing?
Old Feb 19, 2011 | 12:36 AM
Chevycobaltss3's Avatar
ive seen this once, the intake skewed the trims so far off it through a lean code and went limp. also check your plug on the intake and sensors everywhere where u were working. Also get the code scanned soon.
Old Feb 19, 2011 | 02:22 AM
silverbullet08's Avatar
Thread is pointless.. You installed some mods, didnt tune for them, Got a check engine light and want everyone else to tell you whats wrong with your car.. its common sense. Scan the car and find out what the code is then people can help you. If help is even needed. Your maf is probably way out of whack as stated above throwing you into limp mode. You most likely need a tune/or retune. A aftermarket down pipe and intake are going to flow a lot more air through the motor than factory so the computer has no clue what to do.
Old Feb 20, 2011 | 09:18 AM
RYRO14's Avatar
Maybe you put the MAF in backwards? The arrows should go towards the turbo.
Old Feb 20, 2011 | 10:30 AM
bspeed's Avatar
hahah this is what exactly happend to me after i installed the mab bad catless dp, i just checked the codes and ruled them out, unplugged the battery for 20 min then it ended up going away and the maf sensor code came up cleaned the maf then no more issues with low boost 6-7psi my car was lean so i checked under the hood for a leak and it was my dip stick, it wasnt pushed all the way in and was letting air in. check all your hoses too.
Old Feb 20, 2011 | 11:58 AM
cobaltdreams's Avatar
so u think its the maf in reverse or intake leaks that is causing this we are gona tune the car soon as we get all the bolt ons in then tune once so we are not tuneing 5 times. this is my dads car were beginners and doing the best we can. thanks for ur help.
Old Feb 20, 2011 | 12:03 PM
Tazman89's Avatar
Let me guess you have 2 of these? Chevy Cobalt Supercharger
Old Feb 20, 2011 | 01:27 PM
08SStc's Avatar
^^^^IS that a real ad? WTF
Old Feb 20, 2011 | 03:20 PM
what the hell are u talking about man im asking for help with a real question. my dad and i both have cobalts TC same year different colors what does that add have to do with the help we asked for.
Old Feb 20, 2011 | 03:24 PM
Tazman89's Avatar
Its called a joke dont get your panties in a bunch
Old Feb 20, 2011 | 07:47 PM
Originally Posted by ryro14
maybe you put the maf in backwards? The arrows should go towards the turbo.
check that...it's in correct
Old Feb 20, 2011 | 07:51 PM
Negative
Old Feb 20, 2011 | 08:32 PM
clean your maf, verify all is tight and disconnect battery for 10-20 mins.
Old Feb 20, 2011 | 08:36 PM
ssblackstealth's Avatar
corn gas ftw....
cant happen.....the bolt holes wont align to fasten the maf to the pipe
Old Feb 20, 2011 | 08:44 PM
RYRO14's Avatar
Did you ever pull the code? That will most likely tell us what the issue is.
Oh ok didnt know that, seems like if it could it would cause major issues lol
Old Feb 21, 2011 | 10:05 PM
Lets see..on Sunday I pulled the battery fuse for 2 minutes and then reinstalled the fuse...cranked it up..drove to a gas station and filled it up without shutting the engine down...drove 137 miles from Jacksonville to Orlando while getting 15 pds of boost when needed....cranked her up again that same evening and boost was still 15 pds...made two hard runs and all seams fine except I have an engine light on...I'll find out why the light is on tomorrow at the dealer while I get my oil changed....I thank all that actually tried to help without useless profanity.
Old Feb 21, 2011 | 10:35 PM
Zander916's Avatar
I'm with RYRO14.
Scan it and that will point you in the right direction. Hit Autozone, they'll do it for free. Much easier than guessing
Just check all your connections, etc. I left the vac hose off the BPV once. If you want to check quick before you take it to scan it just take your time. Walk through all that you had to disconnect and check them.
Sounds like limp mode to me too.
Old Oct 7, 2011 | 09:49 PM
Originally Posted by zander916
i'm with ryro14.
Scan it and that will point you in the right direction. Hit autozone, they'll do it for free. Much easier than guessing
just check all your connections, etc. I left the vac hose off the bpv once. If you want to check quick before you take it to scan it just take your time. Walk through all that you had to disconnect and check them.
the 6 lbs of boost problem turned out to be a stuck sensor. The dealer replaced it for free...all is good now.
Old Oct 7, 2011 | 09:52 PM
SSlobalt's Avatar
Stuck sensor? Sensors don't "stick."
