Opinion's on a DownPipe!
Old Oct 20, 2010 | 02:35 PM
Turbalt2010's Avatar
hey all i saw the thred on the down pipes but im just curios on who prefers what.
so my question is what DP in your opinion is the best?
i want to keep my CEL off.
so i would assume i need a catted DP. any catted DP's better then others?
Old Oct 20, 2010 | 02:43 PM
Ch1ck3n's Avatar
If you insist on getting a catted pipe, look into ZZP's pipes with the spun metal cats.. Heard good things.
I have a ZZP catless myself.
Just make sure you get one with an o2 bung, can cause lots of problems without it plugged in.
Old Oct 20, 2010 | 02:44 PM
TommyP's Avatar
AWD > FWD
I'm running the badmab catless dp and a vibrant 02 defouler. No CELs after about 800 miles so far.
ok cool thanks for the response.
yeah i wanna do a catted DP because i live in NY and im pretty sure they are strict with emissions.
do you know if some high flow cats will kick on my CEL?
Old Oct 20, 2010 | 02:46 PM
what is a vibrant 02 defouler?
Old Oct 20, 2010 | 02:47 PM
TommyP's Avatar
AWD > FWD
it's a little 90* bent piece of pipe that comes off the 02 bung. Looks like this
I picked mine up from modern performance.
Old Oct 20, 2010 | 02:48 PM
that screws into the bung and then the O2 sensor screws in that?
this will keep your CEL coming on with a catless DP?
Old Oct 20, 2010 | 02:49 PM
davidcroft's Avatar
Or you could just buy a Hahn O/R downpipe and not have to buy a defouler like me
Old Oct 20, 2010 | 02:51 PM
ill have to check that out to!
is it catless or catted? no CEL?
Old Oct 20, 2010 | 05:56 PM
anyone else have any opinions?!
Old Oct 20, 2010 | 06:00 PM
O9cobaltSS's Avatar
i have zzp's cat-less downpipe w o2 bung. i was also dreading a cel but never got one, i have almost 1000 miles on it and it is running fine no cel and sounds great! make sure you disconnect the battery before you instal it, and be gentle with the o2 sensor
Old Oct 20, 2010 | 06:04 PM
you dont have a defouler or anything? and no CEL?
and this is probably a stupid question but why unhook the battery?
Old Oct 20, 2010 | 06:12 PM
O9cobaltSS's Avatar
yea somebody correct me if im wrong but thats what the o2 bung is
disconnecting the batterie will pretty much stop the car from sensing that their is a diff part on the car, in my terms haha i have just always been told to disconect the battery before any performance part is added
yep never had a cel once. as for innspections.. i work at a carwash thats teamed up with a jiffy lube, so i kinda have a hook up.. i hope. their dumb anyways and prob wouldnt even check haha
Old Oct 20, 2010 | 06:21 PM
Ch1ck3n's Avatar
Depends what you are doing. I'd say if you're working with any kind of sensor or anything that might have power running through it, it's a good idea to disconnect the battery just to avoid damage to the part or yourself.
There have been mixed results about still getting cels. It really seems to be hit or miss. Mine doesn't have a defouler so the CEL kicked on within like 30 miles of driving. But I do my own tuning so it was no problem to just turn it off.
I know there was a problem with the MPx catted downpipes kicking cel's on, so they just sent out defoulers to everyone with a problem.
Old Oct 20, 2010 | 06:29 PM
the defouler screws into the bung and make the O2 sensor farther away from the gases and stuff.
im from NY to you think i could meet you at this jiffy lube and hook me up haha
and okay ill just unhook the battery to be safe lol
Old Oct 20, 2010 | 06:32 PM
O9cobaltSS's Avatar
haha id even know if i can get hooked up!! lol like i said tho the place is retarded they prly wld just pass you anyways lol
Old Oct 20, 2010 | 06:35 PM
lol i think ill stick with the highflow cat so this way i dnt get the CEL lol
Old Oct 20, 2010 | 06:36 PM
ecot3c inside's Avatar
get a tune?
and disconnecting the battery doesn't do anything, but prevent you from getting shocked
Old Oct 20, 2010 | 06:38 PM
either way it's your o2 sensor that is going to throw the code and catless or with cat there is still a good chance that you WILL throw a code. Some people get lucky, some people got tuned and the tuner automatically disables the code so he doesn't have to come back.
Originally Posted by moranjames89
get a tune?
im planning on getting a tune. but wont they still pick up the emissions if i have a catted DP with a tune? ik a tune will kick of the light.
Eplain if im missing something here haha
Old Oct 20, 2010 | 06:39 PM
O9cobaltSS's Avatar
haha go for it, good luck with everything man!
Old Oct 20, 2010 | 06:40 PM
lol thanks.
reword this please trying to make sense of it..
Old Oct 20, 2010 | 06:42 PM
lol sorry trying to type fast haha.
ok so you say get a tune, im getting one! lol
even if i get a catless DP and get my tune and have the tuner disable the code wont i still get **** for not passing emissions?
like if the place i go to hooks my car up to the comp wont the see that i dont have a cat?
Old Oct 20, 2010 | 06:51 PM
slapbetcommissioner's Avatar
yes.
a tune disableing the emissions code only prevents them from seeing it diagnostically. when they actually test your emmissions it will be way out..
