Opinion's on a DownPipe!
I think everyone does obd II emissions now don't they? new york? hmmm. well you can always slide your stock back in for emissions sake. I bet they're not going to snake your tailpipe though.
if i have the tuner disable the CEL your saying they wont pick it up at all then?
this is all confusing
if your one of the states that hasn't crossed over to full obdII yet then you get the tailpipe sniffer.
ok since im a certified NYS inspector (I was a BMW/Mini and volvo tech) Ill try to clear the NYS inspection up. The newer cars are whats called OBD II (1996 and newer) all 1996 and newer use a standard plug under the das for diagnostics. The NYS OBD II inspections consist of 2 parts, first the safety seat belts lights ect. The second is the emission portion.... this is where we hook up the scanner and the computer checks for two things the first is any codes that are present and active (you can have codes stored but if they are inactive example an evap code that was tripped the week before when you filled up with the car running... the code is stored but not activethe computer will just skip it) the second thing the emission machine check is if the car is in open or closed loop. it needs to have 2 or more driving cycles in closed loop or it will spit the test out as OBD II sytems not ready ( closed loop mean the computer is using one or more O2 sensor as feed back to adjust the air /fuel mixture. In open loop it used pre programmed tables ) As long as the loop is closed and no codes present the computer will pass the car. My Trans Am has no cats and is far from stock and I get emission stickers all the time.... Just make sure there is no CEL and the emissions guy is ok with you not having cats and your all set.... any questions feel free to ask me.... (sorry about the long ass post)
I would go catless then swap for the stock DP later, when you have to smog it. That is what I'm going to do fore sure. It takes an hour to take it out and put it in. Just once a year... I can handle that. They sniff test in California still, for the most part last time I had to do it so I kinda have to do it that way.
MPx catless installed yesterday, no CEL yet. i bought my cobalt 2 months ago used and found out a couple weeks ago it has gms1. added a K&n drop in. sounds beasty not like a suby tho only gets loud if you really get into it on the stock exhaust and on warm up. Bung came with and a easy fit all around and connection.
I am going to be running a stock modified DP, we are cutting the cats out and replacing with stainless pipe. As far as the CEL's are concerned with the obdII system and emisisons, hp tuners can help you out with that by disabling the secondary O2 sensor.
In closed loop operation the ECU uses one or more oxygen sensors as a feedback loop in order to adjust the fuel mixture. This gives the name ‘closed loop’ from the closed feedback loop. The ECU won’t run in a closed feedback loop all the time, so ‘open loop’ is used to describe the operation of the ECU when the mixture is not being adjusted in this way (usually when the engine is cold or when running under high load).
In closed loop operation the ECU uses the oxygen sensor to tell if the fuel mixture is rich or lean. However, due to the characteristics of the oxygen sensor it can’t tell exactly how rich or lean, it only knows that the mixture is richer or leaner than optimum. The ECU will enrich the mixture if the oxygen sensor shows that the mixture is lean, and lean the mixture if it looks rich. The result of this is that the mixture will swing back and forward around the stoichiometric point.
basically due to the fact the OBDII o2 sensors need to be heated before they start to work properly.... so what happens during the startup process the computer usues a pre-programmed fuel trim (open loop) when they heat up and begin to function properly the ecu uses the data from the sensors to adjust the fuel trim (closed loop) hope that helps.... any other questions just ask.....
