Opinions on stripped meth fitting inlet
Old Jul 8, 2011 | 11:40 PM
JustACobalt's Avatar
i stripped the tapped inlet for what i think is the check valve for my meth setup. the hole is located about halfway down the upper charge pipe and the fitting looks like this AIS Check Valve Fitting - 1/4 NPT To 1/4" O.D. Tubing its the one farthest to the left
what are your guys opinions on the best way to fix this? will a welded piece of aluminum over the stripped hole hold 25-30 lbs? i dont think AIS sells a larger fitting that i could just retap in the pipe. i wonder if i could find some kind of adapter that expands the size from 1/4 to 3/8 or something
Old Jul 8, 2011 | 11:47 PM
HHRSSouth's Avatar
They make weld in NPT bungs, so you could go that route or weld your existing hole shut like you previously mentioned.
Old Jul 8, 2011 | 11:55 PM
D-mac's Avatar
Get a 1/4 NPT bung welded in
If i ever have my Charge pipe out again i shall be doing this also
Old Jul 9, 2011 | 12:07 AM
alright thanks guys. ill be making a trip to ace hardware and see what i can find. ill prob just go the lazy ass route and get a 1/4" female to 3/8" male and use a ton of thread locker.
once i fix this and test for any more leaks, its headin west to term2's crib and back to 24 psi
Old Jul 9, 2011 | 12:54 AM
BooSSted's Avatar
Take the charge pipe out and fix it properly buy having the proper bung welded in place. Have some pride in your car and the work you do on it! It will reward you in the long run.
Old Jul 9, 2011 | 12:58 AM
you're right. wouldnt it be easier just to weld a nut onto it? have to find someone that is willing to weld aluminum to steel
Old Jul 9, 2011 | 01:02 AM
07BoostedG5's Avatar
weld a bung like mentioned or get a 1/4 npt helicoil.
Old Jul 9, 2011 | 05:23 AM
BooSSted's Avatar
Yeah that works too. Just doesn't look great.
I have to do the same thing with my charge pipe so I can install my Meth Kit.
Old Jul 9, 2011 | 09:25 AM
slowstang's Avatar
JB Weld
Old Jul 9, 2011 | 09:27 AM
jb weld the existing hole or jb weld a bung in there?
Old Jul 9, 2011 | 09:46 AM
BYT*SS*TURBO's Avatar
I think he was kidding but it COULD work. JB doesn't hold up well to vibes tho so I would recommend against that honestly.
Best bet is as suggested, get a bung welded onto the CP where the hole currently is, it will give you more threads for the fitting to grab into and stay put!
Tell David I said Hi! Haven't seen him on in a bit
Old Jul 9, 2011 | 10:32 AM
haha i wouldnt use jb weld on the charge pipe anyway. im just going to get a weld in aluminum bung from vibrant and use that. ill tell david you said hi tho when i see him
Old Jul 9, 2011 | 10:54 AM
Thanks man! Hope his new baby and mommy are doing well
Old Jul 10, 2011 | 05:54 PM
alright decided to do it the right way and ordered this guy
Vibrant 11172 Aluminum Weld In Bung 3/8" NPT Female
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
