over rev questions
Old Aug 10, 2009 | 06:19 PM
oopsitouchedmyself's Avatar
over rev questions
Yeah, i must be dumb or something, but the other night i was at redline in 3rd and did a NLS to 4th and somehow hit 2nd gear. the tires were squealing and it backfired and was louder than hell but seems fine. is there anything you guys think i should be concerned with besides learning how to up shift? I figure it put me around 9400rpm for about 1 second or so..
Old Aug 10, 2009 | 06:21 PM
northvibe's Avatar
learn to go through the gears fast before nls'ing.....
RYRO14's Avatar
Nice shift! LOL it happened to me but I think the ECU cuts spark if this happenes because when I did it it redlined then like the engine shut off for a second lol. Any CELs? If not what can you do?
Old Aug 10, 2009 | 06:22 PM
i've been driving the car and shifting like this for the last 12,000miles. just a fluke when i shifted, an accident. like i said, anything to be concerned with besides my shifting?
HB_SS/TC's Avatar
I don't know but your lucky.
I over revved one time and broke the shiite out of my car
Old Aug 10, 2009 | 06:24 PM
no CELS,. no odd vibrations or noises since, but it sure got me paranoid. I keep thinking i'm gonna go startup my car and it's gonna shut right off or something... like a spun bearing or bent valve. i guess this is some proof that these engines are pretty good if they can handle 9400 rpms.. lol
what broke?
Last edited by oopsitouchedmyself; Aug 10, 2009 at 06:24 PM. Reason: Automerged Doublepost
Old Aug 10, 2009 | 06:36 PM
kezia's Avatar
sounds like nothing got hurt, you have to be careful of that you can float the valves and do a lot of damage... i've even heard of cranks breaking. just hear say on the crank so i'm not going to say thats true or not.
it happens to everyone at least once.
Fluffy
Old Aug 10, 2009 | 06:37 PM
well, i've put on about 500 miles since and it still seems alright, so time will tell. I'm interested if anyone else has done this and what damage it did/didn't do.
Old Aug 10, 2009 | 06:41 PM
kezia's Avatar
o its definitely fine then
Fluffy
Old Aug 10, 2009 | 07:54 PM
Gyrocon's Avatar
LoL you must have **** your pants when you did that!
Old Aug 10, 2009 | 09:59 PM
sdmws6's Avatar
if you put 500 miles since then and haven't noticed anything, then you're fine. if something gave during that incident, you'd know it by now.
Old Aug 11, 2009 | 12:27 AM
mikeyc1227's Avatar
It shouldn't be anything to worry about, we all miss shifts at some point.
Just be glad this didn't happen...
http://www.youtube.com/watch?v=MWUbgGarhdc
Old Aug 11, 2009 | 12:34 AM
09turbo's Avatar
at least you didnt do this either
http://www.youtube.com/watch?v=z4G-6Bg9sQA
Old Aug 11, 2009 | 02:36 AM
platinumrims's Avatar
lmao to both those vids..
Old Aug 11, 2009 | 07:09 PM
007G5GT's Avatar
Yup you're fine if 500 miles have gone by and you haven't noticed anything odd.
I did the exact same thing in my old G5 GT and felt like a huge tool for doing so...I'm still baffled that I was even able to get it into 2nd gear so easily. My RPM's tanked to the end of the gauge for a split second before I pulled it out of gear.
I immediately heard a noise that sounded lifter related (reminded me of the lifter tick in my old 4G63 GSX), I annihilated 3 exhaust side lifters. It was all replaced under warranty though and the car was fine after the repair.
Old Oct 16, 2010 | 11:00 PM
northvibe's Avatar
because you dont tell them what you did
Old Oct 17, 2010 | 12:15 AM
blackbird's Avatar
The electronics in the computer can shut off fuel and spark but that does nothing for mechanically spinning the engine up that high because of the gear ratio in the transaxle. The computer has no way to disconnect or override the clutch connection between engine and trans.
Most common failure points in modern DOHC in-line fours when this happens can range from valvetrain issues (rocker/followers to valves floating and hitting pistons in interference engines), timing belt/chain slipping due to tensioner issues, to bearing damage and pistons and/or rods coming apart due to stretching. Some clutches, especially heavier stock dual-mass flywheel setups and other aftermarket setups have also been know to come apart when severely over-revved. If a car continues to run fine afterwards nothing may have immediately broke but I'd be very careful about modifying the car as that doesn't guarantee something wasn't weakened and may not last as long or take to higher stress levels.
Old Oct 17, 2010 | 12:42 AM
dandaman15's Avatar
Dam that sucks. I did the same thing to my car the first time I got on it. I wasnt redlining 3rd though but I went into 2nd and the tires squealed like hell. I didnt let the clutch out all the way though so I think it only went to like 7800, but I have a 2.2. Its been an oil change since and nothing is wrong. However it scared the **** out of me and I didnt try driving that hard for like 2 weeks.
Old Oct 17, 2010 | 12:52 AM
northvibe's Avatar
you were driving...then whatever is the issue at hand, happened. Why do they need more than that? You only give them a basic, I'm stupid and don't know answer, and don't act shady or suspicious and they won't ask questions.
Old Oct 17, 2010 | 02:20 AM
JL-KA's Avatar
Originally Posted by Baron7700
obviously, im trying to think what to tell them...
I told them the truth...just omitted the part where I hit the limiter. Told them I was pulling onto the highway and (hit the limiter) and then went for 3rd and it wasn't there. Tried 4th and it wasn't there. It just spun like it was in neutral. Pulled over and shut it off. That's all I ever told them. They put up a fight but ended up fixing it. I didn't over rev like youre talking about, just bounced it off the limiter. I still have a sneaking suspision that my timing chain tensioner malfunctioned(past ecotechs have been plagued by that). Whatever the cause, they replaced most of the top end under warranty.
Old Oct 17, 2010 | 02:21 AM
JL-KA's Avatar
This. If you act like your car IQ is 0 you're much less suspicious than a car guy.
Old Oct 17, 2010 | 10:02 AM
cardelino18's Avatar
i did this also on my SI a 2 years ago.... i reved it over 10k rpm.... thankfully nothing happend but it sounded baad lol
Old Oct 17, 2010 | 10:58 AM
gotboost?17's Avatar
Nothin Stock
its happened to me blew the rocker and a couple valves....also its happened to my buddys after he let his girl drive it 1-2-1 and hit 9500rpm....now the car is fuckd and neeeds a re-build and mine is fine at least for now
Old Oct 17, 2010 | 11:28 AM
Nothin Stock
i can bet u the rocker and valves are about to go...but im sure the dealer wont do anything till it blows....and im suprised it dint blow bc my tires dint even lock up...FYI do not tell the dealer anything and act like u dont no ****
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
