P0087 and P0089 codes
Old Jan 5, 2017 | 09:35 PM
SECRETARIAT's Avatar
Hello. Have codes P0087 Powertrain and P0089 "Suction Control Valve Stuck Open", no boost, in limp mode, can barely get up to speed. Strong engine, but lots of miles.
​​​​​​​In most cases is this the High Pressure Fuel Pump ?
Thanks, Jeff
Old Jan 6, 2017 | 08:36 AM
Could be in the tune also, and check the wiring to the pump and sensor.
Old Jan 6, 2017 | 09:41 AM
umrdyldo's Avatar
I have had this before it is the giant wire loom rubbing against the fuel pump
Originally Posted by umrdyldo
Right where my finger is the wire loom to the right will rub on the metal frame and the left. When i do oil changes the wire loom will move a little and start the headache over.
With that said, this may not be your issue but please check it before moving to replace pump.
Old Feb 17, 2017 | 03:45 AM
Turned out to be High Pressure Fuel Pump. Replaced pump, problem solved.
Thanks
