P0101 and P0106
Old Jun 18, 2013 | 06:09 PM
RaymondT's Avatar
Canada P0101 and P0106
I just got these 2 codes pending on my car, while crusing at highway speeds. symptoms are loss of all power, and no boost. just changed my plugs and it did it before and after I did this. it also flutters and surges.
Any ideas please help
Old Jun 18, 2013 | 06:30 PM
RaymondT's Avatar
Oh and when i turn the car off, pull the key and restart its fine!
Old Jun 18, 2013 | 07:30 PM
zerosk8ter83's Avatar
maf sensor and map sensor,check to make sure there connected and have no shorts.
Old Jun 18, 2013 | 07:46 PM
QCbalt09's Avatar
Thats because when you shut the car off it reset the computer. I had the same problem when I was running a bov. Depends how yours is hooked up but on mine because the pressure went to atmosphere, they would kick out due to NOT enough air flow. Try this... drive the car for 20 mins and when your not on the throttle make sure your clutch is in ( no deceleration in gear) and see if your boost kicks out or it threw codes..
RHZ
Jul 19, 2012 12:10 PM
C_A_D88
Jul 13, 2012 03:19 PM
pjk91
Dec 12, 2010 04:43 PM
rukkee
Jul 9, 2010 05:55 PM
rukkee
Sep 21, 2009 06:47 PM
