Codes...overwhelmed. Where do I begin the troubleshooting?
Engine: 70k boosted miles on a LE5
I think most of these could be related...where should I begin the troubleshooting?? Completely overwhelmed. I uploaded my tune so you guys can take a look.
Symptoms:
- Especially when the a/c is on, idle bounces around upon taking it out of gear (off load) and coasting to a stop
- Misfires most between 40-50mph under light load (-10,11,12 vac pressure)
- KR in boost @ 3800rpm or higher
Compression test results were 120 across the board. When not in boost, AFRs are fairly steady between 14.6-14.8. In boost, they seem ok but I don't hit it hard because I can't get rid of the KR.
Almost seems like the car won't hold it's tune. I'll tune it, it will run great for a week and then "learn" something and it slowly deteriorates to its current condition.
[ECM] P0101 - Mass Air Flow (MAF) Sensor Performance (Old) (History) (Immature)
[ECM] P0106 - Manifold Absolute Pressure (MAP) System Performance (Old) (History) (Immature)
[ECM] P0121 - TP Sensor Circuit Insufficient Activity (Old) (History) (Immature)
[ECM] P0172 - Fuel Trim System Rich Bank 1 (Old) (History) (Immature)
[ECM] P0300 - Engine Misfire Detected (Old) (Immature)
[ECM] P0420 - Catalyst System Low Efficiency (SES) (Old) (History) (Current) (Immature)
[ECM] P0442 - Evaporative Emission (EVAP) System Small Leak Detected (Old) (History) (Immature)
Symptoms:
jcalvin1126
Sep 11, 2015 10:24 AM
