p0336 car will not run or idle
My car Started throwing a p0336 code after cam install and zzp dyno tune they did all the work. At first the car wouldn't crank first try but second attempt would start right up. Now the car won't even idle it'll crank over but idle just jumps from 400-1300. I have so far replaced the crank position sensor/crank position sensor wiring/main engine wiring harness/both cam sensors/pcm/ checked all fuses and under the fuse box for bent pins and still the car will not idle. As of right now I am at a complete stand still. I've checked the crank sensor plug and I get the readings as stated it should. Any input would be greatly appreciated. Its now down to trying random things IE putting more gas in the tank/changing my oil possibly even dropping the oil pan to see if the reluctor wheel is messed up but the bottom end has never been touched so we are kinda steering away from that.
Mine car did this out of the blue yesterday. I was throwing the same code. Turned out my belt was too loose so it was slipping trying to start and the crank pulley wasnt spinning all the way. Im not saying this is ur problem, just what happened to me.
The book says: (1) Crankshaft Position Sensor rationality check, primary malfunction: unexpected re-synchronization > 2600 count (loss of reference mark) (2) Cam shaft Position Sensor bank 1 exhaust plausibility check: primary malfunction: signal erratic or out of position. Hope this helps.
So not my belt checked that. And it's saying check the exhaust cam sensor from my understanding right
I've changed the exhaust cam sensor already along with the crank sensing kinda just throwing a hail Mary but with a bent pin going to my ecu fuse could that of caused my sensors to slowly short?
only thing i can honestly think of is maybe the sensor i got sent is shot from the factory. We checked the reluctor wheel and it was fine nothing wrong at all.
So the pcm/main engine harness/sensor harness/sensor/reluctor wheel has all been changed or checked to make sure its not broken only thing i can think of is the sensor is faulty maybe
Getaway_Driver
Sep 8, 2015 09:41 AM
Adam144
Sep 3, 2015 07:48 PM
